What's needed to put in a CS144 alternator ?
Old Aug 21, 2014 | 07:57 PM
  #101
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Re: What's needed to put in a CS144 alternator ?
What bolt size fits the back of the CS144 casing? I assume it is metric.
Old Aug 21, 2014 | 08:36 PM
  #102
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Uh. On both my 180* CS144 and 110* the ears are unthreaded. The holes on the bracket were metric thread, though. It's one of those threads that you can thread a standard bolt into and **** up the threads, ask me how I know.
Edit: Reading comprehension.
On the back I don't recall. Pretty sure it was metric, though.
Old Dec 7, 2015 | 05:50 PM
  #103
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I decided to do this upgrade and turns out the one place I could find the bracket/brace Bracket: 10118722, is costing me over 95 bucks!!
Old Dec 7, 2015 | 06:10 PM
  #104
Axle/Gears: 3.27 BW
The better upgrade these days is to repin your harness and go with a AD244 alternator, which uses the same case as the CS130 and the CS130d, and the same plug as the CS130d. You can get them in stock configurations up to 145a, but a much higher amp output at idle than the CS130 or the CS130d, which is really what cars are starved for. Even the lower amperage AD244 offers much better idle amperage.
Old Jan 26, 2016 | 11:45 AM
  #105
BOTTLEDZ28's Avatar
Transmission: A4
I did the AD244 upgrade on my 98 Tahoe. It was a direct bolt, even the stock wiring harness plugged right in. Id like to do this same upgrade on my car come spring but Im thinking the wiring harness and plug will be different. I did find a place online that sold conversion pigtails but I dont remember the site. Ill get on Google and see what I can find.
I cannot confirm if the AD244 is clocked correctly or if it will even drop in but Im sure its worth a try. The AD244 alternator comes in two amp outputs. 130 and 145A. I have been told that GM may have put higher than 145A units in the GMT800 Denalis and Escalades. I cannot confirm this.
Old Jan 26, 2016 | 11:46 AM
  #106
BOTTLEDZ28's Avatar
Transmission: A4
https://alternatorparts.com/ad230-ad...ternators.html
Old Jan 27, 2016 | 11:20 PM
  #107
Denn11's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 305
Axle/Gears: 9 Bolt 3.45
I can confirm that the AD244 will work. Requires slight elongation of the mounting hole and an adapter harness (only if you want to keep your stock harness unmolested). I will post further details when I get time.
Old Jan 28, 2016 | 07:38 AM
  #108
BOTTLEDZ28's Avatar
Transmission: A4
Keep us updated. Let us know if a longer belt is needed. I know I went with a 1" longer belt on my Vortec engine. Also let us know where you get your adapter harness from. Thanks.
Old Jan 28, 2016 | 02:02 PM
  #109
MY87LT's Avatar
Car: 1987 Camaro LT
From what I can see in the pics, you can't use the rear support brace that goes from the back of the alternator to the exhaust manifold anymore?
Old Jan 28, 2016 | 02:21 PM
  #110
AmorgetRS's Avatar
Correct, these alternators don't even have that mounting point.
From reading about the swap on other forums people say that the AD244 case is so much better/beefier that the brace isn't really needed.
RazorN8
Jan 7, 2022 11:44 AM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
