Gauges dont work
Old Jan 18, 2007 | 09:51 PM
84incincy's Avatar
Car: 84 Camaro
Engine: 5.0
Gauges dont work
is there any way to get my tach to work without taking apart the dash?
Old Jan 18, 2007 | 11:24 PM
Gramps's Avatar
Car: 87 Camaro IROC
is your tach the ONLY thing not working on the gauge cluster? mayb its a wiring problem. mayb check your ignition because the distributor sends the info to your gage.
Old Jan 19, 2007 | 06:40 AM
84incincy's Avatar
Car: 84 Camaro
Engine: 5.0
the tach and the engine temp gauge. temp gauge is maxed out and never moves and the tach stays at zero and never moves
Old Jan 19, 2007 | 10:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Twenty minutes work to replace, if that's what's needed. Remove the black plastic bezel, plastic guage face, and metal bezel. IIRC, the tach and temp gauge are held in with a couple of screws. Remove them and simply pull the guage toward you.
JamesC
Old Jan 19, 2007 | 12:28 PM
84incincy's Avatar
Car: 84 Camaro
Engine: 5.0
thanks
Old Jun 1, 2007 | 10:06 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Gauges dont work
Did you ever figure this out? I am having almost the exact same problem.
Old Jun 3, 2007 | 12:32 PM
rsnoody's Avatar
I too have a similar problem only it's my oil pressure gauge and my gas gauge both are straight up. The gas guage corrects itself and works some times.
Old Jun 3, 2007 | 01:40 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Gauge showing all the way "up" often means a discontinuity or short in the circuit (which one, depends on the gauge). Meaning that maybe the sensor is not hooked up or it has a corroded connector or the wire is cut/burnt/grounded somewhere between the sensor and the dash.
Oil and gas gauges show full "up" when the sender wire is disconnected. They show full "down" when the sender wire is grounded.
The temp gauge is reversed: it shows full "up" when grounded and full "down" when disconnected. Troubleshoot by disconnecting and grounding the sender wire, that'll tell you if the gauge or sender is bad.
Tachometer not working could mean that the white wire on the coil had a bad connection or the tachometer module inside the gauge cluster is shot. Only one way to find out: measure the AC voltage on the white wire on the connector behind the tachometer. If you see cca 12V AC (or 6V DC) with the engine running, the tachometer is very likely bad.
Hope this helps.
Lou
Old Jun 3, 2007 | 08:23 PM
84incincy's Avatar
Car: 84 Camaro
Engine: 5.0
now-a-days, my tach works every-so-often. itll work half the 10 mile ride to work varying in speeds from 40-85ish, but never really going over 4000 rpm. it just quits working at random, and thanks for the posts
Old Jun 4, 2007 | 08:23 PM
rsnoody's Avatar
Thanks I guess I got some work to do this weekend. Love this board!
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
