All 4 headlights on all the time? HELP!!!
Old Mar 13, 2007 | 05:38 PM
TS87GTA's Avatar
Car: 1987 GTA
Engine: 5.7 TPI
I have a 1991 chevy camaro RS now but all 4 light stay on all the time
-dim- outside bright inside lights dim
-bright- outside dim inside lights bright
I got pulled over (thought i had my brights on) for this just wondering what to do to fix or if it would pass inspection like this?
Old Mar 13, 2007 | 05:46 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Check the grounds for the headlights. They should be some where near the lights. Also check the body ground off of the battery. Mike
Old Mar 15, 2007 | 11:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My dads Chevy Celebrity did that. As 83z28 said...check your grounds. Also, the your high-beam switch might have gone bad (as on my dads car). What's happening is your switch is sending the wrong signal to the lights. So either it's getting a bad signal...or it's giving one.
Old Mar 15, 2007 | 06:15 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
some people pay extra for that! lol
Old Mar 15, 2007 | 06:41 PM
DMitchell05's Avatar
Guarantee it is the grounding. I had the same prob in another car.
Old Mar 19, 2007 | 04:17 AM
mookie's Avatar
woah you dont want that?? i wrecked my car(its fixed now) and now they all light up and i love it! soon the foglights will be installed
Old Mar 19, 2007 | 12:42 PM
Ozz1967's Avatar
Car: 1984 Trans Am
No, you most definitely don't want them all on all the time. When you click your high beams...in a 4-headlight car, the "high beams" come on and the low beams remain on low (at least that's how it works on my sisters Grand Am). In a 2-headlight car, when you click the highbeams...the high beams come on...fog lights are totally different. Also, make sure you know your state laws regarding fog lights. The Police sometimes are very picky about when they like to see them on.
Old Mar 19, 2007 | 01:33 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
All 4 headlights on means that your high beams are on. That might be ok during a bright sunny day but once it gets dark, you'll be blinding other drivers.
Our headlights consist of one pair of high-beam lights (innner) and one pair of low/high-beam dual-filament lights (outer). With low beams, only the outside lights are on. With high-beams, the outside lights are switched to the other filament and the extra pair of inner lights comes on.
Hope this helps.
Lou
Old Mar 23, 2007 | 03:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BRIGHTS IN THE DAYLIGHT? NOT BRIGHT!
All 4 headlights on means that your high beams are on. That might be ok during a bright sunny day ..............
Might be “OK” but sure looks nerdy.
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
