starter wirering
Old Apr 15, 2007 | 12:51 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
starter wirering
ok im new to this i am in the process of doing a trany swap and all well my friend took off the starter and now he is in jail for a little while i had to get a new starter that would work with my 168 tooth flex plate since my old plate was only 153 anyways i have no idea how the wires go back on i know where the battery cable gose but for the other wires i have no idea on the starter i i have a total of 4 posts 3 on the silanoid and on on the starter motor its self theres a r and a s on on the silanoid and a bolt on the maine part of the starter any idea how to wire this up like i said i wasnt the one who took off the starter or i would of known how it went
here is a pic of the back of the starter to give ya more of an idea of what im talking about
Old Apr 15, 2007 | 01:07 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Re: starter wirering
Battery cable goes to the larger post on the solenoid and the purple wire goes to the S terminal.
Old Apr 15, 2007 | 02:57 PM
Engine: 383 stroker
Transmission: th350
thank you guys for the help
Old Apr 15, 2007 | 04:32 PM
Engine: 383 stroker
Transmission: th350
i ran into a different problem with the starter i dont have just one wire i have three a purple looking wire and what looks like a smaller purple and an orange beside my red batery cable i also have after market gauges
Old Apr 15, 2007 | 05:10 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
If the wires went to the starter the size of the ring terminal should tell you which one it goes on... the terminals are MUCH different in size. I believe the R terminal is empty.
Old Apr 17, 2007 | 03:17 AM
Engine: 383 stroker
Transmission: th350
looks like some wires where added here is what the look like it was taken with my camera phone thats y its blured
Old Apr 17, 2007 | 10:30 AM
DillonRager's Avatar
mine were all on the big terminal except for the purple one which goes on the s terminal
Old Apr 17, 2007 | 10:49 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
PMPN is right, the size of the ring terminals tells you where the wire goes. Put the big ring terminals on the empty big post (yes, the big black cable and the orange wires too) and then put the ONE small ring terminal on the S post. That should do the trick.
Lou
Old Apr 17, 2007 | 12:32 PM
bigbabylou is right just better at putting it in words than i am
Old Apr 17, 2007 | 01:31 PM
Engine: 383 stroker
Transmission: th350
thanks guys for the help i wanted to make sure to do it right i dont want to hurt the starter by wiring it wrong
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
