Installing alarm question
Old May 16, 2007 | 03:08 PM
Project Reaper's Avatar
Hey guys,
I'm installing an alarm in my car and I need to run wires to my signal lights so that the lights blink when the system is armed/dissarmed.
I have two wires comming from the Alarm brain to do this.
1 for each side.
Problem is that I'm not sure where the best place is to tap into the signal lights.
Any help would be great.
Thanks.
Old May 16, 2007 | 05:44 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: Installing alarm question
For a keyless remote sytem, I tapped into the wire coming out of the headlight switch. I used the wire going to the parking lights. That one wire takes care of flashing front & rear parking lights at once - was very simple & works like a champ!
Corky
Old May 16, 2007 | 06:21 PM
Corky
Thanks for replying
How do I figured out wich wire goes to the parking lights?
I cant seem to get behind the headlight switch to access the wires either.
Any other ideas?
Old May 16, 2007 | 07:24 PM
Corky's Avatar
Engine: 2.8L
To figure out the correct wire just use a test light as you turn on the parking lights. You want to connect to the wire coming out of the headlight switch that powers up the parking lights. The alarm system wire will provide power to the parking lights to flash them. I don't have a wiring diagram handy to trace where that wire ends up. Perhaps one of the gurus can chime in and give you another location.
As a personal preference, I try to keep all wire splices out of the elements & inside the car whenever possible.
Corky
Old May 16, 2007 | 07:39 PM
randy4762's Avatar
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
Originally Posted by Project Reaper
Thanks for replying
Any other ideas?
Look under the dash, near the back of the fuse panel or in the kick panel for a brown wire, there are plenty. Use a meter or testlight to verify the wire is not a dimmer wire by turning the headlight **** to see if the test light dims.
If it dims do not use it as it will cause the dimmer to burn out. Otherwise it is pretty simple to do.
Let me know if you need anymore help. Randy
Old May 16, 2007 | 08:56 PM
Ok,
What position should the headlight **** be in when I do this?
Should it be pulled all the way out (headlights on) or should it only be pulled out the first bit (just parking lights on)
Thanks. I will check for that brown wire when I hear back from you.
Old May 17, 2007 | 08:06 AM
randy4762's Avatar
Ok,
Just pull it out to the first bit. Then check wire with test light, turn p-lights on/off a couple times to make sure, then also with p=lights on, rotate dimmer to make sure the test light does not dim with the dash lights. Thats it!
Randy
Old May 17, 2007 | 09:28 AM
Randy
Thank you Sooooo much Randy.
I will pick up a test light and do just that.
Thanks again.
Curtis.
Old May 18, 2007 | 09:54 PM
Once again, Thanks a Ton Randy and Corky.
I tested out every single brown wire I could around my fuse box and behind the drivers kick pannel and not one of them was the right one.
Soooooo.
I took the top of the dash off.......again. and I was able to see the wires going to the back of the light switch/****.
I used the test light on one of the brown wires there and sure enough it worked for the parking lights. I also adjusted the dimmer to make sure it didn't dim my test light and it did not.
I then ran a cable up through the dash to that point and tapped into that brown wire there.
All is done and working now.
Getting the lights hooked up turned out to me one of the toughest things, That and finding a hole in the firewall to run the siren and tapping into the power door locks were all quite tricky. The rest was easy.
Thanks guys.
Old May 20, 2007 | 02:10 PM
Corky's Avatar
Engine: 2.8L
You're quite welcome - now you are an expert ready to help the next person with a similar question!
Corky
Old May 24, 2007 | 03:21 AM
electricshack's Avatar
I tapped mine to the headlights, too. My friend had his alarm wires tapped to the signal lights. He has no any problem so far.
________________
Jerry
GM 4L80-E Transmission Controller - Get the new Transmission controller in GM Performance Parts 2006 Catalog by GM Parts Direct
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
