positive battery cable
Car: 92 trans am clone
Engine: LO3
anybody have a picture of a positive side of the battery cable off of a trans am with tuned port injection? if not how would this looks what would be on it and how long exactly? how would the negative cable look for the same vehicle? any chance the v6 has the same positive battery cable?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: positive battery cable
I don't think theres a difference in the battery cable you use, as long as it is long enough, not sure how to answer the question.
Engine: LO3
well im curious as to what is attached to it because i know it goes from + to the starter and then i dont know what else is on it. is it only the cable that has a cylinder in the wire its hard to explain but its up near the battery and i dunno if thats the only other thing
Engine: LO3
ok i got te 7x" positive cable from terminal to the starter but i dont know what else attaches to the terminal
Im sure that another wire would have to go to the fuse panel. possibly the ignition as well, but im just guessing.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The smaller wire is connected to the alternator for charging purposes.
gta892000
Sep 16, 2015 12:37 AM
