Grounding Aluminum Heads to the block?
Old Nov 2, 2007 | 05:58 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
good idea or bad idea or it doesnt matter?
MSD told me that with thier ignition box, coil, and dizzy...the AL heads do not make a good ground...that it would help if I ground the heads somehow to the block...which I did..
Im thinking it couldnt hurt
Old Nov 2, 2007 | 05:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Grounding Aluminum Heads to the block?
Shouldn't make any difference.
Old Nov 2, 2007 | 06:09 PM
ok..well aslong as it doesnt hurt anything...I guess I'll leave it
Old Nov 2, 2007 | 06:40 PM
Guest
Guest
Posts: n/a
Boy thats a new one. What will they think of next?
Dont talk to that guy at MSD again.
Old Nov 2, 2007 | 07:01 PM
why do you say that?...so your saying its a bad idea? or it wont make a bit of difference?..should I remove it?
aluminum is a good ground?
Old Nov 3, 2007 | 03:42 AM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Won't hurt anything, though. Leave it if you want.
Old Nov 3, 2007 | 11:53 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it wont hurt anything, but aluminum is a better conductor than iron anyway, and the heads are bolted to the block in many places, so i fail to see where there would be a grounding issue, besides, the battery ground is connected to the head right? and the ground strap from the engine to the chassis bolts to the head right? so where is the issue?
Old Nov 3, 2007 | 11:56 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Shouldn't that be accomplished by simply bolting the heads to the block?
EDIT: //<86TA>\\ thought of this before me
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
