Manual Shift Pattern Light
Old Jan 16, 2008 | 02:57 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Hi guys
Whilst taking apart my console in order to install power seats, I discovered that there is a light bulb socket under the manual shift pattern. There is even a piece of red "lighting gel". There was however no bulb in place. I've been searching this forum looking for the right bulb number and I thought I had it narrowed down to a #194, but I bought a couple and they are way too big. They must have been referring to the auomatic shifter.
Anyone know the right number for these little bulbs?
Thanks, Tom
Old Jan 16, 2008 | 03:08 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Manual Shift Pattern Light
The one I have says...GE 168
Old Jan 16, 2008 | 04:06 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
i don't know...i just went in to get one for my '88 manual and all the computer came up with was automatic...of which i bought that one brought it home, and it worked. I know for sure that it isn't a 194...but i can't find a number on my replacement. So sorry i can't help you there. But i don't know whats available to you in canada but i went to carquest here and they had it.
actually just went and looked and it was etched with "174". They do change the numbers around after a few years (had this problem with fog lights...they were one number off), so i wouldn't be suprised if it's either mentioned so far but i just picked up a 174 yesterday and it works. I don't know if that helps at all but good luck!
Old Jan 16, 2008 | 04:13 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
a # 24 is a smaller wedge base gauge/marker light, its smaller than the 194's it was used as a rear side marker on caddys and olds alot
Old Jan 16, 2008 | 08:46 PM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
I had a look at the 168, it looks the same size as the 194... the only bulb that looked like a match was the 73 or 74... smaller version of the 168/194... guess I'll have to try them!
CHeers Tom
Old Jan 24, 2008 | 08:09 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
anyone have a pic of this lighted shift quadrant? obviously camaro's didnt have this as mine dosent'
Old Jan 24, 2008 | 09:43 PM
kcb37's Avatar
My 89 has the shift boot, shifter. On the console behind the shifter a little plate with the shift pattern but no light. (can't be one solid black plastic)
What do you have. Pontiac?
Old Jan 25, 2008 | 06:29 AM
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
The 74 bulbs worked
Cheers Tom
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
