WTF???
Old Feb 11, 2008 | 05:33 PM
IRCONMIHEAD's Avatar
WTF???
I own a 1985 IROC TPI
PVC pipe touched positive terminal on alternator now it idles at 3,000RPM Constantly...What could be the problem?
Check Engine Light is on and the car will start and voltage reading is at normal 13v.
Old Feb 11, 2008 | 05:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: WTF???
What code is it setting?
Old Feb 11, 2008 | 05:43 PM
Re: WTF???
I do not have a scan tool, and I'm broke. I know someone on here experienced this unless he/she removed the pvc pipe. Could it be the ECU one guy at O'RELILYS Auto Parts said it needs a new ECU and another one said it wouldn't start with a bad ECU. I hope its something simple grounded on the block....I have no clue what to do or test? I have Volt Meter I just dont know how to test any sensors..... Hey Thanks for your response it means a lot
Old Feb 11, 2008 | 05:45 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: WTF???
go to autozone and have them do the free "check engine" light check. go from there.
Old Feb 11, 2008 | 05:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: WTF???
You don't need a scan tool, just a paperclip.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Feb 11, 2008 | 05:54 PM
Re: WTF???
Cool thanks! where is the DCL Connector located? also would it still be a bad ECU even if it starts?
Hey thanks again it means a lot
Old Feb 11, 2008 | 05:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: WTF???
It's under the dash to the right of the steering wheel. I doubt you have a bad ECU.
Old Feb 11, 2008 | 06:02 PM
Re: WTF???
I hope I dont have a bad ECU, okay I know what your talking about now. So by doing this it will cancel out which ever trouble code its throwing?
Old Feb 11, 2008 | 06:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: WTF???
Doing that will tell you what the computer's complaint is, so you can figure out what the problem is and how to fix it.
Old Feb 11, 2008 | 06:09 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: WTF???
Did the short melt a hole in the PCV line? If so repair the hole.
Old Feb 11, 2008 | 06:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: WTF???
That's what I'm thinking, too.
Re: WTF???
Almost it came close to melting and started metling inward. I'll give another look because the metal pipe leads to a rubber one and that could of melted. I had the alternator checked and its good but I dont see how the bolt started melting also isint there a fuse inside the alternator that could burn out if this happend?
Quick check and couldnt see or find any leaks (Whew!!! I'm outta shape)
Last edited by IRCONMIHEAD; Feb 11, 2008 at 06:19 PM. Reason: Automerged Doublepost
Old Feb 11, 2008 | 06:24 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: WTF???
did you check the codes yet?
Old Feb 11, 2008 | 06:33 PM
Re: WTF???
I'm not going to lie, no I havent. I just dont have the money to purchase it or enough to have it towed to AutoZone. I'll try my best to get those codes. To all who answered I owe you one Thanks for your time a patience. I'll repost asap when I have the codes.
Old Feb 11, 2008 | 06:47 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Re: WTF???
You just need a paper clip or piece of wire. connect the two terminals on the upper right of the ALDL then turn the keyon and count the blinks of the check engine light. The first code will be 12 repeated 3 times. Mike
Old Feb 11, 2008 | 07:02 PM
mercdeking's Avatar
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
Re: WTF???
I bought the expensive paper clip option at autozone or was it checkers for checking my check engine light codes. $19.99 or so, good investment for me!
Old Feb 11, 2008 | 11:16 PM
Stephen's Avatar
Car: 87 GTA
Re: WTF???
When they said paper clip, they meant....just an OFFICE paper clip. No need for any fancy tool. You spent $19.99 too much.
No need to tow the car anywhere, or even start it. Plug the clip in, turn the key to the on position, then read the Check Engine light flashes.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
