Cold out car wont start
Old Feb 11, 2008 | 07:01 PM
the311godfather's Avatar
This thread may sound something like it dosen't belong here but hear me out. I have 92 camaro rs 305 and it recently quit starting. I cleaned some corrision on the battery cable on the starter and it running fine and it hit -15 deg f. All it dose is click at the starter. Should i replace the battery cable and if so how. Any help please
Old Feb 11, 2008 | 08:07 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Cold out car wont start
Battery is dead.
Old Feb 12, 2008 | 11:55 AM
The battery is fully charged i took it up to murray's auto and had it charged, any other suggestions? possible voltage regulator or wires need to be adjusted on the starter?
Old Feb 12, 2008 | 12:01 PM
402 GTA's Avatar
Car: 86 GTA
Engine: 402 cbb
Transmission: th350
Axle/Gears: 9" 3.50
Did they do a load test on the battery? Just because it is "charged" and showing 12V does not mean it is a good battery.
Old Feb 12, 2008 | 12:07 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
The next time the starter is just clicking take a hammer and whack it a couple of times and if it works then your starter is bad.
I doubt it is your battery.
Old Feb 12, 2008 | 01:02 PM
I didn't have them do a load test on it i'll proably do that today after i get off of work. I took the starter off and had it tested, they said it was good.
Old Feb 12, 2008 | 08:15 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Might be the cable. Test for battery voltage at the starter solenoid.
Old Feb 13, 2008 | 11:22 AM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
with that really low temp, you may want to investigate water freezing inside the starter. that happened to me once or twice.
Old Feb 13, 2008 | 09:47 PM
So I found out that my batter was completly froze. when i took it out yesterday and shook it to here the fluids i herad nothing moving. i brought it inside warmed it up put it back in and the car is running again...for now. thanks for the help and suggestions everyone.
Old Feb 14, 2008 | 06:28 AM
DJP87Z28's Avatar
As I said "Dead Battery". Do the easy things first and don't make something hard on yourself.
Old Feb 14, 2008 | 01:22 PM
Thats why i went and brought the battery in before doing anything else. Gotta love cold weather though
Old Feb 14, 2008 | 01:56 PM
DJP87Z28's Avatar
Belive it or not Hot weather kills more bateries then cold. I had them go bad in 90deg weather.
Old Feb 14, 2008 | 10:50 PM
Thats not hard to beleive, but for some reason i usually have problems with cold more then heat. seeing that michigan has the most unpredictable weather. I never had a problem with heat here, it runs perfect when temps are in the hundreds. Running at higher temps is a faster way but it's usually just my luck that it happens right when it's the coldest around here, that could be 5 deg to -15. My next journey is finding the vaccum leak which i have no idea where.
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
