I beg for assistance.. ign box
Old Feb 19, 2008 | 01:06 PM
devilfish's Avatar
Sry for my bad english.
I got a hyfire 6al from a good friend. Need some assistance install it.
The probleme is that I cant find the colours on the wires that the manual is referring to.
I provide a picture. Hope you can guide me.
The car is a 1991 vette with lt1intake and a smal cap dizzy and a external coil from a 1987 camaro.
Thanks so much for your time.
Regards
Anders.
ps: does "splice" mean to cut it and dont use it, or just leave it stock and "merge" the cabels togheter ? ..
Old Feb 19, 2008 | 06:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: I beg for assistance.. ign box
I`ll try to help...
"Splice" is going to mean cut the stock cables (wires) and connect to the proper colored wires coming out of the hy fire IMO. Cut the wires that are at the coil that say not used and cap the ends on the coil side..Now the other ends that come from the harness hook up to the white wire and small red coming out of the hy fire.
As for the tach I would think you would use the white wire coming out of the box and connect it to the white that was cut at the coil. I would make sure the small red wire into the box has battery + positive when the key is turned on... hope this helps some
Old Feb 19, 2008 | 06:41 PM
devilfish's Avatar
Thanks alot for helping.
When you say "cap the ends", do you mean to cut it, and then just isolate the ends?
And for the red wire, can I use the pink wire from the "car" that goes to the coil ( labeld "not used" on the picture ). I think that is 12v on ignition. I can mesure it first to be sure.
Again, sry for the bad english...
cheers..
Old Feb 20, 2008 | 06:04 AM
yes, whatever is cut and not to be used anylonger, isolate so no short can happen. and if the pink that`s not being used is ign on + , then I would use it.
Old Feb 20, 2008 | 02:09 PM
devilfish's Avatar
Thanks so much.. I hooked everything up. And the only thing that still buggs me is the white wire coming from the stock tach. Original that wire is connected to the white wire from the coil ( the one that say "do not use"...
Is it ok to reconnect the tach to that wire. Or do I need to use the yellow wire from the hyfire?
thanks
Old Feb 20, 2008 | 05:03 PM
Try the yellow wire and see if it works right, there`s got to be a reason the diagram shows 2 different spots.
Old Feb 26, 2008 | 06:20 AM
devilfish's Avatar
Thanks for your help I got it to work now.
I just connected the tach where it says "connect factory tach here" hahah cant belive i missed that
Thanks for clearing things up
Old Feb 26, 2008 | 05:39 PM
Glad to help
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
