Turn Signal Not Blinking!
Old Feb 20, 2008 | 10:28 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
ok i've read thru some threads, but have to ask. Changed all burnt bulbs, but right front turn not blinking. when lights on, light is bright like when it blinks, just stays bright? could this be flasher?
Old Feb 20, 2008 | 11:14 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Turn Signal Not Blinking!
i had the same problem i just took the bulb out and cleaned out some gunk that was in there and it woked fine
Old Feb 21, 2008 | 08:05 AM
Car: 92 Lo3 RS
Transmission: t-5
them seemed to be clean, will have to check. thanx. anyone else got an idea?
Old Feb 22, 2008 | 01:47 PM
Brads RS's Avatar
Its a dirty connector most probably, sounds like its back feeding. Make sure all your connctions are clean.
Old Feb 22, 2008 | 01:50 PM
Car: 92 Lo3 RS
Transmission: t-5
i'll go check if thier dirty now. would it be the one that is real bright or any one of the 2 on that side that is not working/blinking?
Old Feb 25, 2008 | 12:57 PM
jaron's Avatar
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
its most likely that you've replaced it with the wrong bulb, check the actual bulb, it needs to have two filiments inside, if it's got only one then that could most likely be your problem as its trying to light a second filiment but there isnt any
Old Feb 25, 2008 | 02:04 PM
Car: 92 Lo3 RS
Transmission: t-5
all fixed, thanx for help. the connection was bad somehow. took bulb out, looked into connector, it looked clean. still i decided to clean contacts. bam came on right away. somehow wasn't dirty but was.....anyhow works now. thx
Old Feb 25, 2008 | 09:11 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
good job Willie cleaning always works wonders
Old Feb 29, 2008 | 02:02 PM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
What did you clean it with?
Old Feb 29, 2008 | 08:09 PM
Car: 92 Lo3 RS
Transmission: t-5
my pinky finger, lol! yeah check it out, just take out the one your having problems with, take cloth or swab or etc and clean actual contacts that touch bulb. what problem r u having?
Old Mar 1, 2008 | 09:42 AM
Car: 1986 Camaro
Engine: 350 v8
all me driver side lights stay solid when i turn on my left blinker
Old Mar 1, 2008 | 09:52 AM
Car: 92 Lo3 RS
Transmission: t-5
was one burnt out prior? mine was, i replaced that side frnt and back, then front stayed lit, took bulb out, wipe off new bulb again, clean contacts, leave bulb out while trying this, make it easier. it's simple problem. keep trying.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
