Engine swap now need help wiring
Old Feb 25, 2008 | 01:52 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Ok, I just swapped from a 1988 305 TBI to a built 383.
One of the problems I expected is wiring. I know that I can get it running using the old wiring and I will have lots of extra leftover wires and such. That is not my goal.
I want to keep my air conditioning. I tried to swap all the sensors that were on my old engine over to the new one. I have 2 coolant temp sensors, 3 Oil pressure sensors. (I'm not sure why there were 3, one is the sender for the fuel pump, one is for the gauge and idk what the other is for.) I have my alternator starter and fan. Then I also have an electric choke, distributor and MSD 6A box.
I would have LOVED to get rid of the ECM and all the spare wires and wire something else myself, but unfortunatly I dont have the knowledge to do such a thing. I also think that the computer controls the air conditioning and some of the sensor/ senders.
Can anyone help me out big time on what I should do?
Old Feb 26, 2008 | 08:10 PM
Engine: 388 Carb
Axle/Gears: 4.10
Re: Engine swap now need help wiring
Bump??? I want to get rid of as much wiring as possible but keep some of the creature comforts...
Old Apr 2, 2008 | 08:25 PM
89YellowJacket's Avatar
Car: 89' Camaro RS
Engine: Stroked 350 ???
Transmission: 4-speed manual
Axle/Gears: ???
1985, i'm in the same boat as you. picked up camaro that had v6 mpi converted to 383 carbuerated, got a lot of loose wires. trying to search and see anybody else has already done this and listed what wires to keep and what to cut out. good luck.
Old Apr 2, 2008 | 09:30 PM
Engine: 388 Carb
Axle/Gears: 4.10
I've been doing my research alot more and found that not many of the components run through the computer. You need to either wire the fuel pump to your ignition or to a switch. Other then that the rest of the wires connected to the computer can go. The Gauges are all run seperatly apparently. The fan switch i am working on but am pretty sure it is seperate from the computer, maybe someone can chime in with some advice. Even the A/C is seperate then the computer. If you find any good info let me know.
Old Apr 4, 2008 | 07:54 PM
Car: 89' Camaro RS
Axle/Gears: ???
the sticky on v6 to v8 swap, the part of the harness says that the main harness will disconnect from the vehicle or separate from the vehicle. the main harness goes through the firewall to the fuse box. will i need to seperate from fuse box? the sticky makes it seem easy, i must be missing something. i am trying not to chop up the harness, but i have separated the wire loom from wires to find certain accessories that are in the wire harness. am i on the right track?
will follow from fuse box and remove wires i don't need. i know that from searching the post that there is some conflicting info. but i will succeed and get my baby running. this is good first wiring project with good exp. thanks.
Old Apr 4, 2008 | 08:03 PM
Engine: 388 Carb
Axle/Gears: 4.10
you should be able to get it running, then work on getting rid of the other wires, and the computer isnt on the same side as the fuse box... If you get it running, which isnt really hard, all you need is power and ground then you could disconnect things when its running to see if you need it or not. Thats one way to do it atleast
Old Apr 4, 2008 | 08:27 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
i hate to say it but i think autozone.com has wiring diagrams...i think I got mine from there.
Old Apr 4, 2008 | 08:49 PM
Engine: 388 Carb
Axle/Gears: 4.10
I have access to all the wiring diagrams, my boss has ALLDATA PRO, there are just so damn many of them because there is no such thing as a schematic for it apparently.
Old Apr 8, 2008 | 02:55 PM
bigzeke's Avatar
hey guys im new to this forum but am building my second f body my first was a 84 camaro i now have a 92 firebird what i can tell you is that if you are going carb then you dont need most of the harness ,i bypassed the fuel pump and installed a pickup ,removed electrical pump and am running a external holley w/regulator ,the onle other mods to the harness are changing out alt pig tail ,installing pigtail for hei ,as for my fan and pump they are all ran off toggle switches with fused links as far as all those sensor ends i cut them out i havent had any troubles thus far bottom line if youre running hei you only need fire to the dist and fuel ,hope this gives you a little encouragement ,im sure ill need you guys for something in the future thanks oh going to post pics soon of 92 firebird 355 fuelie heads kb,s ,solid cam ,3800 convertor 4.10 gears big zeke
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
