Seat belt chime.....
Old Feb 29, 2008 | 04:50 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Did a search and couldnt really come up with what i was looking for so here it is. simple questions:
1. How do i disable the buzzer for just the seat belt?
2. What would happen if i took out the buzzer completely?
Old Feb 29, 2008 | 04:58 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Seat belt chime.....
You guys have a buzzer!! That sucks lol. That is one reason I am glad to have an older car. I dont even have to worry about that stupid idiot light, that my last car used to tell me I wasnt buckled up.
Old Feb 29, 2008 | 05:15 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
we have a buzzer alright. praise the lord you dont have one for your seat belt.
Old Mar 1, 2008 | 05:54 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
well i figured out the buzzer today, just figure id post in case anybody else had the same problem.
- With buzzer module completely removed, there will be no buzz but also no dummy lights. i.e service engine soon or infl rest.
- buzzer module must be in harness for dummy lights to function correctly.
- to disable buzzer ONLY but keep module in harness so dummy lights work correctly:
1. take out buzzer module
2. open up buzzer module by suppressing the clips that fasten the unit together.
3. remove circuit board from case.
4. on the upper section of the module casing, remove white plastic ring, metal circular piece, and metal support brace that connects circuit board to speaker.
5. reassemble the buzzer module and plug it back into harness
6. enjoy not having that annoying buzz anymore in your camaro!
Old Mar 1, 2008 | 06:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Even my 85 has the buzzer. As long as you're not stoooooid enough to forgo the belts whenever you climb into the car, the buzzer doesn't count.
JamesC
Old Mar 1, 2008 | 07:29 PM
Engine: LO3
Was having no seat belt light or buzzer a firebird only thing then? I usually dont wear my seatbelt because the ones in these cars are so uncomfortable. Any other car doesent really bother me, but the one in my firebird is so tight the way it sucks into your gut. I wonder if that is because its a "sports car"??
My cousin got an 06 civic, and it has little scales to see if someone is sitting in the seat. I rode in his car once and we were about 100ft down the road, and *beep beep beep* hes like dude you gotta buckle up, or that thing will stay on the whole ride. LOL
Old Mar 1, 2008 | 08:27 PM
JamesC's Avatar
[QUOTE=slow_90firebird;3660823I usually dont wear my seatbelt because the ones in these cars are so uncomfortable.[/QUOTE]
Your life (though it really belongs to your loved ones). Around here recently, ten fatalities, 10 poor dumbs saps not wearing seat belts. I and my family wear them 100 percent of the time. As far as I'm personally concerned, there is no excuse for not wearing them.
JamesC
Old Mar 1, 2008 | 08:41 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Originally Posted by irishhockey34
...enjoy not having that annoying buzz anymore in your camaro!
Also, if you only want to take care of the seatbelt chime (and seatbelt fasten light) simply cut the YELLOW wire in the harness that goes to the (in)convenience center. That will disable only the seatbelt chime and light.
I still prefer to have the chime because it alerts me if my lights are on since I drive with the lights on most of the time...
Old Mar 2, 2008 | 07:32 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
That's a new one... but would you rather be a little unconfortable when you drive your car or possibly end up dead?
Old Mar 2, 2008 | 08:01 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Anyone know why mine would go off randomly throughout the drive? (I have my seatbelt on, and so does the passenger) I usually don't hear it through the music, but when its off, it gets annoying.... every 5 or so mins.
Old Mar 2, 2008 | 11:34 PM
HCR13's Avatar
Car: 1987 Trans Am
you should check the chiming box (blue box) in the convenience center, its probably faulty...
Old Mar 2, 2008 | 11:43 PM
Engine: LO3
Well, I am just a problem to my loved ones, they really dont love me that much I dont think. They would rather I was never born. But I suppose if I die then they will be left in the wake of my debt for a long time...
I dont mind wearing the seatbelt sometimes, but other times it just bothers the crap out of me. Plus I always take it off if I am snow driving or somethng, because it interferes with my ability to react and steer quickly.
So down to what I was wondering, does that mean if I have no seatbelt light, or chime, that a previous owner disabled it? Because I have the headlight chime and the key-in-ignition chime.
Old Mar 3, 2008 | 12:14 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
How old are you talking about? My '73 Trans Am has a seatbelt warning light and buzzer. The real great part is that the buzzer won't turn off until you buckle up! 1974 is even better. It was federal law that year that all cars sold in the US would NOT start unless the front seat occupants were buckled up first. More than a few congressmen got threatened to be voted out of office over that one ...
TheBigJ, I occationally had the same problem on my '84 Trans Am. If you open up the chime module you'll find a round disc(potentiometer/timer) that goes through the circuit board. The factory solder isn't very good and as the potentiometer heats up over the years it eventually gets a bad contact which will make it function at random. Resoldering it with some high temp solder will fix it for good.
Old Mar 3, 2008 | 04:41 PM
TheBigJ's Avatar
Car: 85 Firebird
Thanks I will try that out!
Old Mar 4, 2008 | 06:27 PM
Bounty600's Avatar
Car: 89 Firebird
Engine: 5.7L V8
haha my chime doesn't usually go off because I think I have a short in it. :P Like I put my belt on every time I get in it, but it doesnt even tell me I dont have my belt on as I usually start it before I buckle up. When it does come on it will chime for 2 chimes and then just kind of die lol maybe it the speaker for it? lol
Old Mar 4, 2008 | 06:59 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
my chime is on the second i open the driver door, and doesn't go away until you close the driver door. Haven't figured that issue out yet.
Old Mar 4, 2008 | 07:24 PM
Dens71TA's Avatar
That is the key reminder chime. It the chime is going off when the door is opened and there is no key in the ignition lock then there is something wrong with the contact adjustment in the steering column.
Old Mar 4, 2008 | 07:31 PM
84redta's Avatar
well i think the tumbler is shot...is a PITA and annoying as all hell, you need to jiggle it and move it and yea...not fun, not to mention...manual cars...is there supposed to be a spring holding up that little lever?? Mine is settled down and to turn it into the on or run position you need to lift that up once you get it to actually move into acc. I also have no acc. Tumbler and possible spring adjustment/replacement gonna fix all that???
and yes, it's with the key out of the ignition, thats what i assumed that it was the chime for the key...but only prob was there was no key in there, lol.
Old Mar 4, 2008 | 07:38 PM
Dens71TA's Avatar
Yes, that little lever on manual trans columns is suppose to be up. You're suppose to have to press down on it to be able to turn the ignition cylinder to the LOCK position and remove the key. It sounds like your steering column could use a good disassemble, cleaning, and rebuild.
Old Mar 4, 2008 | 07:46 PM
84redta's Avatar
by rebuild you mean fix the sprining action of that manual arm button and a new ignition tumbler right...? Not some outragious $100 kit...? Suprised...only thing that works well on the damn steering column is the tilt, tight as the day it left the factory i assume as there is no jiggle what so ever. Locks in every time. What exactly is the spring for the manual arm button...? can i just jimmy rig a spring in there to have it work like it should, i've combed the junkyards, not going to find a manual car any time soon, not to mention it would be a pain to try and tear a 20+ year old car in this weather to see it break on me. Is there a readily available part or something?? Haven't done any research, was the last thing on my list to touch upon.
Old Mar 4, 2008 | 10:10 PM
Car: 1987 IROC-Z
Transmission: TH350
1. Driving in the snow is when you are more prone to be in an accident.
2. You don't want to turn suddenly when driving in the snow because you will easily lose traction and the car will just keep on plowing ahead until friction is finnally able to slow it down.
Old Mar 5, 2008 | 12:38 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That will also disable all the buzzers (key in ignition, lights on, etc). To disable just the seatbelt buzzer, unplug the connector next to the driver's seat and under the plastic cover for the seatbelt take up reel. I think it sends a ground to the light and buzzer when there is no tension on the seatbelt.
Old Mar 5, 2008 | 02:53 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Old Mar 11, 2008 | 06:14 PM
kabal's Avatar
where is the seatbelt buzzer module located mine is not working
where is the module located mine is not working the seatbelt light just stays on
Old Mar 11, 2008 | 06:21 PM
kabal's Avatar
how do i find my buzzer module please advise my light for the seatbelt stays on and the buzzer does not sounded either
Old Mar 11, 2008 | 07:14 PM
HCR13's Avatar
Car: 1987 Trans Am
Its in the convinience center. You have to remove the driver's side underdash panel, and it would be next to the radio pod (behind the service port(?))... do a search, you'll find it..
Old Mar 12, 2008 | 03:19 PM
kabal's Avatar
by replacing the seatbelt module would this stop the light from staying on all the time and does anybody have a picture of the module for a camaro 1986 z28 or any of the those years i know all of the 1980,s are similiar
Old Mar 14, 2008 | 01:13 PM
kabal's Avatar
if i were to switch the passenger seatbelt to the drive seatblet would this help to turn off the seatbelt light please advise
Old Mar 14, 2008 | 01:54 PM
HCR13's Avatar
Car: 1987 Trans Am
no. it would not help...check out this thread, first post, I have a picture of the convenience center, the blue box is the "chime box" and the yellow wire controls the seatbelt light...
Old Mar 16, 2008 | 07:30 PM
kabal's Avatar
can somebody tell me or have a picture of the buzzer for a camro for the seat i would like mine to work thanks
Old Oct 17, 2018 | 03:48 AM
katrav8's Avatar
Car: 1982 trans am
Engine: 4bbl carb 305 v8
Transmission: 3 auto
To sum up a previous owner might need to disable seatbelt chime by cutting yellow wire or is there another easier way?
I personally do not like this idea and would like to know how to solve this mystery.
Seatbelt branch plug is connected to wire under seat allready.
Old Oct 28, 2018 | 08:48 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
I'm not sure why people are saying to cut the yellow wire, I guess it depends on the year. My '92 service manual says the black wire connects to the seatbelt switch "Open with LH Seat Belt Buckled". So you can either bend/break the "E" tab on the inconvenience center alarm module, cut that black wire (on a 92 at least) or just disconnect the connector at the seat belt base (which is the easiest and reversible way to do it).
*edit* Always wear a seatbelt. I feel funny not wearing one, but don't need a 'reminder' to put it on. As some others have mentioned, it's really annoying when working on a car.
Old Nov 30, 2019 | 12:28 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
were do the wire for the driver side seat belt hook up to while replacing the sleeve the wires came loose have no idea were they go
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
