an engine diagnostic tool to read gauge senders?
Old Mar 9, 2008 | 12:40 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
is there such a device that i guess you would call it an engine diagnostic tool
a tool when you track down the sender for your oil pressure or cooling temp for your interior gauges that you can un plug the wire and plug in the hand held diagnostic tool and on the lcd display it will be abel to read the ohmage (ohms) from the sender and tell you the engien is at 220 degrees or oil pressure is at 42psi etc.....
i'm just wondering that this must exist somewhere to help garages.
i want it because i installed digital gauges and want for my own comfort to know they are reading correctly
any help would be great thanks
Old Mar 9, 2008 | 08:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: an engine diagnostic tool to read gauge senders?
It's called an ohmmeter, and its a normal function of most multimeters.
Old Mar 9, 2008 | 08:57 PM
400HP88IROCCONV's Avatar
Car: 2007 R/T-R package CHARGER!
Actually there is a diagnostic tool from Snap-on called the "MODIS" which will show you in great detail on a color screen where a specific sensor is, which wire to test, how to test it, and the best way to gain access to it. It will show you (in real time) your actual sensor output levels, from which you can compare these to diagnostic charts (already preprogrammed into the "MODIS") and determine if your sensor is T.U.
Or you can just use a DMM
Old Mar 9, 2008 | 09:07 PM
Bobby_80s's Avatar
Axle/Gears: no idea
your right about the DMM
but how about decoding it to tell me in PSI or temp
like 50ohms = 23psi etc.....
also a DMM has two leads.
negative and positive
theres one wire from the senders
the senders r grounded so negative to the sender lead and postive to a 12v source?
actually dumb question sry guys its ben a hile since i took electronics in high school.
but seriously 1 wire out of teh sender and two leads from the DMM how do i read the ohms across the sender?
Old Mar 9, 2008 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The sender is a resistance to ground.
Old Mar 9, 2008 | 09:16 PM
Bobby_80s's Avatar
Axle/Gears: no idea
anyone know of a chart that says ok you got 15 ohms from the sender that means ______ in psi or in temp
because the ohm is just part of the puzzle
Old Mar 9, 2008 | 09:33 PM
Most diagnostic charts I've seen will show you min/max values for a desired sender, and the desired value for a specified reading. I think the best books I have are a TPI swapper book I bought 20 years ago, and a GM manual for one of my c4 vettes
Old Mar 9, 2008 | 10:55 PM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
I can tell you how I am planning on verifying the accuracy of my analog guage...
by putting the sending unit in boiling water, I'll be able to get an acurate ohm reading at 212 Deg.
once I have that, I'll be able to get a variable resistor from Radio Shack. set it to the correct ohm reading and connect it from ground to the sender lead.
That way if my dash guage reads ... lets say 230... I'll know when to get worried becouse it is actually 212.
I was hoping to be able to adjust the guage... I looked on my spare instument cluster and don't know if it's possible. (do you think pulling the needle off and moving it would be accurate???)
Tony
Old Mar 9, 2008 | 11:16 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i installed aftermarket digital gauges so thats why im trying to get them as accurate as possible.
already replaced the temp sender, gona need a little help doing the oil pressure sender.
the gauges have high and low ***** i can turn to get the right reading but i need to know what the correct reading is first.
Old Mar 10, 2008 | 07:27 AM
Bobby_80s's Avatar
Axle/Gears: no idea
if anybody has a site that will have the ohm chart that would be great im looking for one now and i guess i'll have to start looking for books if i come up empty
thanks for all the help guys
Old Mar 10, 2008 | 10:31 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
This will help you with the temp senders:
https://www.thirdgen.org/forums/atta...ase-ctsmat.gif
Lou
Old Mar 10, 2008 | 10:36 AM
Bobby_80s's Avatar
Axle/Gears: no idea
perfect thanks lou,
anyone have a ohm chart for the oil pressure sender?
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
