HID's
Old May 8, 2008 | 10:24 PM
Stu's Firebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 305 5.0L V8
Transmission: Stock
HID's
I have the conversoin kit to make my headlights the H4 Bulbs. I put some HID's in there and the wiring harness only lets you use the low beams as the only power source to go to the ballasts, so then I when i go to the high beams they just go off. I was wondering if there is a way to wire it so when I turn the brights on they stay on. I tried connecting the high beam hot wire to the low beam wire but when I turned them on the switch just sstarted smoking!! Any ideas ??
Old May 8, 2008 | 11:03 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: HID's
Im guessing you have one light for low & hi beams. If so your HID's will have to be duel filament type in order to have low & hi beams, you may just regular HID for a setup with more than 2 headlights. Also you won't nead hi beams if you have HID's. My camaro has 10,000K bulbs & their bright as #@%?.
Old May 17, 2008 | 03:08 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Re: HID's
If you hooked your hi beams to your lo beams and you still had halogen hi beams then you probably toasted the halogens. HID's run at about 75 volts and 400 hz. If you had HID bulbs in the hi beam locations then you probably overloaded the ballasts and let a little smoke out. You can only run one bulb per ballast. If you want hi beams you need 4 HID bulbs and 4 ballasts. If you knew in advance you can order a kit called Bi-HID that simulates hi beams by changing the focus of the bulb up when the hi-beams come on. It works real good but your lo-beams and hi-beams come out of the same headlight, your other 2 headlights are just along for the ride.
Old May 17, 2008 | 06:33 PM
Car: Too many cars
Re: HID's
Im guessing he has only 1 light per side due to it being a 3rd gen bird.
Old May 18, 2008 | 09:32 AM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Re: HID's
Your right Karl, I need to check the signature more often. If you still want to rig it so the lights don't go out when you hit the hi beams then check this site out http://faqlight.carpassion.info/headlamp-harness.html It is a little extra work but the only safe way to do it.
Old May 18, 2008 | 05:11 PM
Car: Too many cars
Re: HID's
Hey Norwood is it a good idea to put a relay in if you use HID's, I keep getting diff. opinions.
Old May 19, 2008 | 10:26 AM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Re: HID's
Well nobody can tell you it's a bad idea, but I don't think it's necessary on 3rd gens. Newer cars have special electronics that monitor current thru the headlights to check for problems and blown bulbs. The only time our headlight swithches carry more current with HIDs is during the first few seconds when we turn them on, after that they are carrying almost half as much amps. So if we are careful and don't un-necessarily turn them on and off and turn them on after you start the engine (the starter interrupts headlights) we should have no worries. Also remember that restarting HIDs after they have already warmed draws more amps than when they are cold.
Old May 19, 2008 | 10:08 PM
Car: Too many cars
Re: HID's
Thanx Norwood, sorry to jack your thread Stu.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Fronzizzle
Aug 19, 2015 01:36 PM
F-Body Tim
Aug 20, 2004 09:40 PM
CrazyHawaiian
Oct 1, 2003 09:41 PM
MrDude_1
Jul 12, 2003 06:04 PM
