Headlight control module
Old Jun 4, 2008 | 12:49 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My headlights don't come up unless I tap on the headlight control module, and I can't seem to find it on autozone's or oreilly's website. Is it possible to rebuild these? Or is there anywhere locally I could get one? The only place I can find that sells them is top down solutions, and I was hoping to get the car inspected thursday.
Old Jun 4, 2008 | 01:15 AM
Stephen's Avatar
Car: 87 GTA
Re: Headlight control module
You could always put them up, disconnect the motor to lift/lower them. Just to pass inspection.
As long as they stay up, you'll pass that part. Now if you were to turn them on, & they wouldn't come up? You'd fail. But they won't care if they are now "locked" into the up position. Just unplug the motor & they are "locked up". Plug it back in after you get home.
But no. Nobody local has them. You MIGHT find am electrical guy willing to look at the module, but TDS is the only place I know of that routinely does them.
Your problem is also why I kept the spare one I got!
Old Jun 4, 2008 | 01:27 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Hah, you know I didn't even think of rigging the headlights to stay up, to pass inspection. My dad is an electrical engineer, so he could probably take a look at it. If it's something obvious like a bad solder joint or loose connection, I can probably fix that. I guess tomorrow I'll pull it off and see what I can do with it, if I can't fix it I'll ghetto-rig the lights to stay up. Thanks for the info!
Old Jun 4, 2008 | 01:37 AM
Stephen's Avatar
Car: 87 GTA
No ghetto-rigging needed. Get them to go up, the unplug the motors, turn the lights off & they'll stay up!
If you can't get them to go up by the tapping (been there, done that), use the manual **** on top of the motors. That's why the **** is there. For motor failure, yet you can still get them up & down.
For that matter, the manual method SHOULD still allow you to pass. Nothing says it can't be manual & has to be electric.
Old Jun 4, 2008 | 09:20 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I'd agree, it does sound like a bad solder point or something.
Also, there is a relay in the HDM, I believe. If the contacts are a little charred, that might cause the bad connection too.
Resoldering most of the joints should do the trick. If not, I'm sure your dad can troubleshoot it, it's a very simple circuit.
Keep us posted!
Lou
Old Jun 4, 2008 | 08:34 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well I pulled it off today, and had my dad look at it. A couple of the solder joints on the connector pins looked iffy, so we re-soldered them. The relay contacts looked a little burned too, we cleaned them as best we could with an x-acto knife. It seems to be working again, but I don't know for how long. I'm betting that the relay contacts were the problem, but it doesn't look too hard to replace the relay. That is, assuming I could find another one somewhere.
Old Jun 5, 2008 | 01:07 PM
BigBadLou's Avatar
Engine: TPI
Old Jun 5, 2008 | 03:04 PM
Stephen's Avatar
Car: 87 GTA
I took a piece of sandpaper, cut into a 1/8"-1/4" wide strip & slid it between the contacts & sanded the contact surfaces, sliding the paper back & forth. Flipped the sandpaper over & did the opposite contact. Might have been able to double the paper over & sand both together, didn't try though.
Old Jun 6, 2008 | 02:29 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, it sort of worked. The passenger side headlight comes up every time, but the driver side sometimes doesn't. If I tap on the headlight module, it comes up. I think I'll try pulling it apart again, and trying the sandpaper method on the relay contacts. It looks like the relay has four contacts, two for each headlight motor (up and down). I guess the driver side "up" contact didn't get cleaned good enough.
Old Jan 27, 2012 | 09:21 AM
blackfrontier's Avatar
Car: 89 GTA & 76 T/A
Engine: 5.7/455
Transmission: GTA Auto/76 T/A 4speed
Does anyone have pics of the relay or can point me to where it is? Mine don't come up either once in awhile and I don't hear a motor turning so I'm thinking it isn't a bushing issue.
Old Jan 27, 2012 | 09:36 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
On the firewall, just left (looking into the engine bay) of the brake booster.
There are 2 versions:
86-89 http://www.top-downsolutions.com/hea...d54b1351c76b4f
90-92
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TrevinE
Sep 14, 2015 03:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
