Lo beams not working
Old Jun 21, 2008 | 05:40 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
My hi beams I believe (the 2 inner lights) do not go on. I even bought a new headlight today and put it in. I pull the light switch all the way, then pull the turn signal lever, and nothing. I tried every possible way and they do not go on.
Old Jun 21, 2008 | 05:57 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Lo beams not working
The inner lights are the hi-only beams. The outter pair is switchable between low beams and high beams.
Your lo/hi beam switch might be out of adjustment, judging from your description. Try this tech article: http://www.austinthirdgen.org/index.php?pid=16
Sometimes it helps to tilt the steering wheel all the way up or down when switching the beams.
Hope this helps.
Lou
Old Jun 21, 2008 | 06:05 PM
92 Camaro's Avatar
Thanks. I will try doing this and will ask any questions if i need to.
Old Jun 22, 2008 | 07:34 PM
92 Camaro's Avatar
Odd. On that page you showed me, the switch it blue/white, but mine is all white?
Old Jun 22, 2008 | 07:38 PM
MasterFab's Avatar
Car: 85 Berlinetta
Engine: 2.8
I had a similar issue with mine and it was as simple as checking the ground wires on mine
92 Camaro's Avatar
Ground wires for the lights? Where?
Old Jun 22, 2008 | 07:42 PM
MasterFab's Avatar
Car: 85 Berlinetta
Engine: 2.8
mine were grounded right out of the harness behind the plug
Old Jun 22, 2008 | 08:02 PM
92 Camaro's Avatar
Hmm plug. Do you mean one of these?
And how do I fix that problem?
Old Jun 22, 2008 | 08:06 PM
MasterFab's Avatar
Car: 85 Berlinetta
Engine: 2.8
on the plug at the headlamp its self...i dont believe that it is a switch issue. There should a ground wire that comes out of the harness and goes to the core support
Old Jun 22, 2008 | 08:13 PM
92 Camaro's Avatar
Before I go crazy tracing it, where exactly does the harness begin under the hood?
Old Jun 22, 2008 | 08:17 PM
MasterFab's Avatar
Car: 85 Berlinetta
Engine: 2.8
start at the headlamp and work backwards....it should be only an inch or so away from them....
Old Jun 22, 2008 | 09:06 PM
92 Camaro's Avatar
I forgot to mention...when i try to put the lo beams on, my highs shut off.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BBSDesigns
Aug 11, 2015 07:39 PM
