what is.... (help please!)
Old Oct 7, 2008 | 03:56 PM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
what are the two plugs that are to the right of the brake booster. two large connectors that have a small bolt holding them to the firewall..?
to me it looks like they run the lights and some other components???
Old Oct 7, 2008 | 10:52 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: what is.... (help please!)
Your right or my right?
Sorry, couldn't help myself.
A picture is worth a thousand words.
Or describe the connectors better with a thousand words.
Ok, at least give us approximate size, color, number of wires, maybe wire colors ...
There are several connectors by the brake booster, relays, the main C100 through-firewall feed etc.
Lou
Old Oct 7, 2008 | 11:02 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
The radiator fan relay is in that general direction
Old Oct 8, 2008 | 12:16 AM
BeerGut88's Avatar
i need a light module for a 1986 camaro berlineta for my little brother who is fighting in iraq i despretly need this part. any info drop me a line thanx.
Old Oct 8, 2008 | 12:40 AM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
https://www.thirdgen.org/forums/elec...highlight=c100 ( look at this thread, the plug im talking about is the third picture down)
i beleive the c100, which the plugs were totally fried looking and there was all kinds of nasty black silicon so i just cut the wires, then unbolted the plugs and pulled them off. The male part of it i guess you would call it it in good condition, and still in the firewall. Im guess i need a new harness then (cause i cut it off).
what does the c100 run???
Old Oct 8, 2008 | 01:13 AM
jeffcj's Avatar
If I recall correctly, some or all of the following comes through C100
Oil Pressure gauge sending unit
Tach wire
Distributor wire.
Basically all gauge wiring...
I'm sure that isn't all inclusive, but those are a few.
Old Oct 8, 2008 | 01:53 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Yes, it's the much ignored C100 bulkhead (or firewall) connector.
It runs most of the wiring between the engine bay and the interior (power feeds (in & out) for lighting, ignition, & starting circuits, plus what jeffcj said & a lot more.
Only the ECM is on a different harness.
The black goo inside is supposed to be that way & is for corrosion protection.
Yes, you'll definitely need to get a new harness, now that you cut it..
Old Oct 8, 2008 | 06:40 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah the inside of that plug usually looks pretty bad. Cutting it was not necessary and will probably cause you more headaches down the road. My suggestion to you at this point is to find another engine bay harness (not an engine harness) that matches your model and motor and vehicle options.
Then replace it and run the wires everywhere and start out fresh.
There are some important wires in there. Starter wire, power feeds for the inside of the car, lights, and some other odds and ends. During my swap I dumbed that wiring down as far as it could go, and I was still left with a handful of wires that I needed for the inside of the car to function as well as for the starter to work off the key.
J.
P.S. Just for future posts. The plug that you described is on the LEFT of the car. When referring to parts on a car and using the terms left and right, you usually pretend like you are sitting in the car. So the booster is on the left. If you want to be 100% clear, then say passenger side/drivers side. Just to help ya if you have more questions!
Old Oct 8, 2008 | 08:21 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
This is what you cut(see attached) Big mistake on that one. it is the main harness for the engine and lighting check out the diagram I have included.
When I did my tpi swap the harnes i got had this cut off. I had to rebuild it using the tpi harness and tbi connector. it was a PITA!!! I did this as I did not have the money to buy a new harness. The cheapest I could find was over $200.00
Old Oct 8, 2008 | 09:43 AM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
damit... stupid move on my part. Ok well thanks for all the information! it really helped out.
So im guessing ebay/junkyard/classifieds for a engine bay harness (c100)
3rdGenSS
Dec 23, 2005 03:30 PM
ws6formula
Nov 18, 2005 02:05 PM
Saigon_Bob
Nov 2, 2005 08:25 PM
hemipower_31
Brakes
Oct 20, 2005 07:39 PM
