Blinker problem
Old Oct 10, 2008 | 08:24 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Blinker problem
Alright, well I'm completely confused. My left blinker doesn't work. It is always lit up in the dash, but when I actually turn the blinker on it gets even brighter, but just stays lit and doesn't blink. When I turn it on, the rear blinker light becomes solid as well as the front blinker. But the side marker light doesn't work. When I turn my lights on, the side marker light becomes a solid light and the front blinker light goes out. The right side works just fine though. Any help is greatly appreciated.
Old Oct 10, 2008 | 10:04 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Blinker problem
That's odd. I have the exact same problem on my '91 GTA.
Old Oct 10, 2008 | 10:07 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: Blinker problem
I'm thinking it has to do with something inside the column. It stopped working when my column became really lose and then we fixed that but didn't look at the switch or anything. But if anyone can let me know if that sounds right, please do so.
Old Oct 10, 2008 | 10:35 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Blinker problem
i had the same problem with my camaro a year or 2 ago. so i was messing around with it and all i did was clean out the bulb socket in the tail light blinker and then the front and back work again so try that.
Old Oct 10, 2008 | 10:46 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: Blinker problem
Well..I don't know. They all work now, just at the wrong times. Can't hurt to clean them, though.
Old Oct 10, 2008 | 10:52 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Blinker problem
thats how all the lights where on my maro they onley worked sometime like with the taillight i would think they worked until my sister would be drviing it and gets pulled over for the tail light being out then when going to change it it worked. and with the blinker it would blink sometimes but not others so i just cleaned them all and every light works now so it allwas good to keep them cleaned up
Old Oct 10, 2008 | 11:48 PM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Re: Blinker problem
I had the same problem with a 88 camaro my wife had...
we searched the car over for loose ground wires .... non found
then used electrical contact cleaner (I think its made by 3M) on all the bulb sockets... worked fine after that... wish that was the only problem the car had...
Old Oct 13, 2008 | 12:41 AM
irocz28boy's Avatar
Car: 2000 Z28
Re: Blinker problem
Well I'm finally free from school and work tomorrow, so I guess I'll try cleaning them really well. I hope that fixes it. Thanks guys.
Old Oct 13, 2008 | 05:32 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Blinker problem
check the bulb in the socket make sure it wasnt put in backwards (forced in the oppsite way of the prongs on the bulb) ive seen that before
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
