swaping v6 instruments out for v8?
Old Oct 13, 2008 | 07:59 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
i did a search and didnt see anything on this. my camaro was a v6 89. and im putting in a v8 . what do i have to to to be able to run a v8 instrument pannel. or can i just add a resistor to the v6 tach to get a v8 signal
Old Oct 15, 2008 | 09:08 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: swaping v6 instruments out for v8?
If your car originally had a gauge cluster in it - you could simply install a V8 cluster or specifically a tach, or you could add a converter to correct the V8 distributor pulses to a V6 signal so your existing V6 tach will be correct. A stock V8 Tach will probably be much cheaper than a Tach converter.
If your car had a 'dummy light" cluster than you can install a V8 gauge cluster and simply install the sending units needed for the gauges. ( Temp, Oil press ) The wiring is already present in your dash harness - you would just need to add the V8 gauge cluster and the sending units to make it all work. That's only true for Camaro - Firebirds with dummy light dash clusters do NOT have the gauge wiring present in the dash !
Old Oct 16, 2008 | 05:20 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i guess i need to find astock camaro gauge cluster. with tach sep from speed. not with other gauges.
Old Oct 16, 2008 | 06:39 PM
eeeeeefirebird's Avatar
you could always go to an autometer tach
Old Oct 18, 2008 | 01:08 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i already have a procomp ultralight 3 3/8 tach and 3 3/8 speedo electronic up to 200 mph. but i was just wanting to try and keep it more stock looking inside. i might just get the covan classic instrument pannle and add the rest of the pro comp gauges. if i could find a v8 gauge cluster cheap i would rather do that. just for now.
Old Oct 19, 2008 | 03:41 PM
John in RI's Avatar
You don't even need the whole cluster - Just the Tach. V8 tachs have a 30/60 oil pressure guage and the V6 ones show 40/80 on the oil pressure guage.
Old Nov 6, 2008 | 11:48 AM
igotmailed's Avatar
Car: 1983 Firebird SE
Engine: 305 5.0 V8
Hey John
I'm doing a gauge swap from a V6 firebird that has dummy lights and bought the gauges from a V8 305.....do u know best route to wire up this gauge cluster since the OE wires are not present on the firebirds?
Old Nov 6, 2008 | 12:19 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Originally Posted by igotmailed
Hey John
You'll need more than just the gauges for a Firebird. This is from the tech section - a search would have found it.
http://www.hioutput.com/tech/speedo.html
Old Nov 7, 2008 | 10:06 AM
John in RI's Avatar
The Way I work; I would swap the complete dash wiring harness. I would rather unplug - plug in the right dash harness rather than cutting, splicing, running additional wires.
I'm sure that it would be easy enough to add a few wires to the cluster plugs and run them thru the firewall for the Tach and/or electric speedo - but I'd rather plug and play !
wulfie-916
Apr 15, 2014 01:20 PM
sabresfan
Jul 4, 2011 11:25 PM
Xandarin
Apr 16, 2008 11:43 PM
87transkid
Nov 26, 2005 09:53 PM
