Alternator Wiring Help
Old Dec 1, 2008 | 08:07 PM
hotrod7687's Avatar
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
Hey guys, got a question about alternator wiring. Excuse the jerry-rigged carb and wiring for now, I was only looking for a quick fix so I could drive it home after I bought it.
Ok, the car is an '84 Z28. I have the wire running directly from the positive battery post to the alternator, then from the 2 prong plug coming off the alternator the larger of the 2 wires goes back to the alternator and connects where the battery cable does. From the wiring diagram I studied this looks to be right.
My question is about 3 wires coming from the harness near the alternator. There were 3 wires, 2 approx. 10-12 gauge wires and one much smaller wire, all of which were cut and about 1/2 in of wire was exposed. You see one wire in the pic that starts out black and is spliced into a red wire that goes to the alternator on the same connection as the battery cable, I dont think this is the right place, but the car didnt have any power at all until I connected this wire here. The other larger wire which you can see in the pic just above the oil fill cap is still not hooked to anything. the smaller of the 2 wires coming from the alternator plug is spliced into the smaller of the wires coming from the harness. The car runs right now, but I know its not hooked up right. Could someone point me in the right direction as to where the wires coming from the harness go?
Old Dec 2, 2008 | 04:32 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: Alternator Wiring Help
The small plug-in on the altenator, one goes to the battery terminal on the back of the altenator and the other one should have 12volts ignition feed or 12volts while running. I beleive the 12volt feed comes from the GAUGE fuse if I remember right.
Old Dec 2, 2008 | 11:15 AM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
the connecters on the alternator are 2 trigger wires and i think a constant hot not quite sure i know one of them goes to the fuse box like john said but i dont think it was a gauge fuse do u have a wiring diagram of the chargin circuit?
Old Dec 2, 2008 | 11:31 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
on mine i ran a wire to the left prong on the plug in to the back of the alternator and another wire from the back to the battery never have any issues if you want to do it that way
Old Dec 2, 2008 | 11:35 AM
87transGTA's Avatar
Car: 87 GTA
how many pins did ur connecter have? mine had 4 total
Old Dec 2, 2008 | 11:57 AM
mario82z28's Avatar
there are only 2 prongs on the alternator were the plug goes into i did away with plug and wired it as i said above as long as you plug into postive side should be fine
Old Dec 2, 2008 | 12:08 PM
87transGTA's Avatar
Car: 87 GTA
oh ok my connecter is diffrent and the alternator connecter is also diffrent my alternator has 5 pins on it where the connecter goes in and the connecter has 4, two brown wires, red wire,and a yellow if im not mistaken
Old Dec 3, 2008 | 06:46 PM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
I think i have the same problem, i have one wire that I can't seem to see where it goes. the battery is hooked up to the back, I plug in the the little plug which has 2 wires. one heads to the back of the engine and the other is just hanging out. I read through all the replies and not quit sure where it all leads to.
did you ever figure this out?
Old Dec 3, 2008 | 10:32 PM
hotrod7687's Avatar
I still haven't found out where everything goes yet. I havent had a chance to look at since I made that post. Tomorrow I'm going to get out there and trace the wires back, so hopefully I'll know something then. If I find out I'll send you a PM.
Old Dec 6, 2008 | 11:10 AM
87transGTA's Avatar
Car: 87 GTA
do you think that might be a ground?
Old Dec 6, 2008 | 06:49 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
I did think it was a ground at first, but it is red and it doesn't reach anything to ground to. If i need to I'll just get it to a shop and let them figure it out. The thing that bugs me is that I know its simple and I just can't see it.
I beginning to think that I bought someone else's botched project.
I still have high hopes. little by little I'll get back the way its supposed to be.
I guess i could put a volt meter on it, that will tell me if theres juice or not.
Old Dec 6, 2008 | 09:59 PM
bigbird89's Avatar
Car: 86 Firebird
It was my inderstanding that the red wire went to the large terminal on the starter solenoid. I just got my car running and that's where I ran it. The car runs fine although I can't say how well the battery is being charged. I would like some more knowledgeable input too.
Old Dec 7, 2008 | 07:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link is for a serp conversion, but should provide enough info to be helpful:
http://paceperformance.com/index.asp...=Custom&ID=650
JamesC
Old Dec 7, 2008 | 10:21 AM
87transGTA's Avatar
Car: 87 GTA
did you try tracing the wire to see where its from and if u got juice on it it might be the one that goes to the starter
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
