ignition fuses?
Old Dec 7, 2008 | 06:21 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ignition fuses?
which fuses in our dash box comes on with the ignition source? i gotta run some toggles for my nitrous selonoid, and fuel pump relay. which ones can i tie into? also is the heater fuse an ignition source? i dont have a heater so might be able to use that?
Old Dec 8, 2008 | 06:21 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
WE HAVE IGNITION . . . .
The blower motor fuse is on the switched circuit.
You can use that one.
Happy Racing!
- Race clean!. . . . . . . . . Do it on dirt! -
Old Dec 8, 2008 | 10:35 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: ignition fuses?
There are three blank ignition source spaces(keyed) in the lower left corner of the fuse block, and there are three blank battery source spaces(hot always) near the lower right corner of the fuse block(by the circuit breakers and stop/hazard fuse).
They're there for adding accessories, because car makers know that no one is ever satisfied... people always want more! They're even labeled appropriately, or, at least, they were when they were new... might've worn-off over the years: "ign" and "bat," and they each have tiny arrows pointing to them.
Old Dec 8, 2008 | 11:04 AM
Engine: 355
Re: ignition fuses?
i tried puttin a fuse in it but the prongs dnt spread for the fuse to fit. do i gotta use different fuses? also i can use the heater fuse?
Old Dec 8, 2008 | 11:31 AM
LAFireboyd's Avatar
Re: ignition fuses?
They might be tight if they've never been used, but they should open-up.
But those spaces aren't for fuses. They're for accessories' hot wires, so they only hold a single, spade-type(flat) male connector on the end of the hot wire. The hot wire for the accessory will usually have its own fuse within an inline fuse holder.
Old Dec 8, 2008 | 11:48 AM
Engine: 355
Re: ignition fuses?
o cause i went down and the center that goes between the two prongs on the block isnt "cut out" the middle of the fuse bottoms out on it before touching the fuse connections
i prob jus use the heater fuse and bump up the amp fuse size for two toggle switches. will that work?
Last edited by billybob6110; Dec 8, 2008 at 11:52 AM. Reason: Automerged Doublepost
Old Dec 8, 2008 | 11:52 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: ignition fuses?
how many amps do you need to run through them and what guage is the wire? i have a factory diagram for a 90 camaro, with color coding and i can look it up for you.
Old Dec 8, 2008 | 12:03 PM
Engine: 355
Re: ignition fuses?
im not sure its gna be for my fuel pump relay and a switch for my nitrous selinoids/microswitch
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
