HID's????
Old Feb 1, 2009 | 11:08 PM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
HID's????
Figured it was close enough to post here.
I was wondering if anyone has been able to put HID's in there thirdgen Camaro? I have Sylvania Silverstars and would like ot get HID's, as they arent bright enough.
Post up pics, and how you did it.
Old Feb 2, 2009 | 08:51 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: HID's????
Yeah a few guys on here have them. I just ordered a system off ebay for about $60. I also ordered a new wiring harness. If you get H4 bulbs it should be a direct replacement. Someone correct me if im wrong.
Old Feb 2, 2009 | 09:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: HID's????
You need the housings to convert the sealed beams to replaceable H4 bulbs and an HID conversion kit for H4 or 9003 bulbs. I've always liked this pic I took:
Some companies make halo housings too:
Old Feb 3, 2009 | 01:29 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
Are these the same housing you can find on Ebay?? Where can I get the wiring harness? I can get a complete HID kit for $50 shipped, all I would need is the housings and the I guess the harness.
Old Feb 3, 2009 | 11:41 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: HID's????
All of the housings I have are ebay ones. There's no wire harness needed, just an adjustment to the placement of the terminals in the stock connector is all. Some people like to run relays and use the stock wiring as the trigger for it, but I don't think it's needed. If you get a bi-xenon HID kit it will have its own relay system built in anyway though. I'd double check that HID kit is for H4 bulbs. I have seen kits that cheap, but not for H4 or other dual beam bulbs, specially if it's a bi-xenon kind.
Old Feb 3, 2009 | 08:07 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
Ok Great. I was trying to figure out how to get HID's to work with the stock housings. I really didnt want to take them apart to try and get it to work.
The HID's are that cheap, I got a set for my silverado from teh same guy and they work great. I dont think I will use the Bi Xenon kit as My Hi and Low beam arent the same bulb. Thanks for the info.
One more question about the Ebay clear lenses. I have had to replace 2 sets of my Parking lights due to moisture forming in them. Even tho the moisture goes away after some time. Do any of your ebay lenses(headlights,fog lights, parking lights) have a moisture problem afte you wash your car? Did you seal them any special way ro just install them and forget it.
Old Feb 3, 2009 | 08:18 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: HID's????
If you're talking about the camaro, the only bulbs that I'm aware of that you can get, H4's, have dual beams which require some way of dual beaming the bulb. I did have moisture problems like you say, but that was because the rubber cap got a cut in it. They usually seal quite well to the bulbs, but you could zip tie the outer part to help seal that.
Old Feb 3, 2009 | 08:36 PM
TheMuskr's Avatar
Re: HID's????
Just ordered 2 pairs of the ebay lights. Pretty cheap i just hope their good quality.
Old Feb 4, 2009 | 10:05 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: HID's????
There are a ton of threads on this. A search should provide you with plenty of info. Here's a couple to get you started.
https://www.thirdgen.org/forums/auto...300k-hids.html
https://www.thirdgen.org/forums/elec...nversions.html
Old Feb 10, 2009 | 07:55 PM
TheMuskr's Avatar
Re: HID's????
just got mine all installed today. i love the look. mine are 4300K
Attached Thumbnails HID's????-20090210173313.jpg   HID's????-20090210173255.jpg
Old Feb 11, 2009 | 04:15 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
The muskr, Could you send me a PM on where you got your kit from, or how you did it?
Old Feb 11, 2009 | 12:54 PM
TheMuskr's Avatar
Re: HID's????
Yeah for sure im at school right now and work tonight. so il try to do it asap
Old Feb 11, 2009 | 08:00 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
Re: HID's????
can you just post the them on here? i im very interested in converting my lights into hid's
Old Feb 11, 2009 | 08:08 PM
krisb410's Avatar
Re: HID's????
You know guys, I did HIDs a long, long, time ago. I found out how by doing searches and some basic research. All the info was already on here. 1st thing I learned is those ebay euro lights, or what ever they are called, are absolutely horrible for HIDs. Get "E"" code housings. And do a search, you may find my thread from way back when, explaining how I did it.
Old Feb 11, 2009 | 08:49 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
I have already searched and didnt find the answers I was looking for. For how many pages there are of things going off topic. I would just rather ask someone who just did it for a little info.
Old Feb 11, 2009 | 11:54 PM
TheMuskr's Avatar
Re: HID's????
Okay well. i Just bought a regular HID kit off of ebay. any one with H4 bulbs will work. then i bought the new 4x6 H4 housings off of ebay. I also got a wiring harness from 3bspecialties.com. Which I recomend for peice of mind. All you need to do is find a good place to mount the ballasts, hook up thhe new harness, and replace the sealed beams with the new H4 housings. I also just put cheap bulbs in the brights just so they were functional. I'll try to get links asap.
Old Feb 12, 2009 | 12:02 AM
TheMuskr's Avatar
Re: HID's????
LINKS
Harness- http://shop.3bspecialties.com/produc...0&productId=22
HID's (you dont need this one, any with H4 bulbs will do)- http://cgi.ebay.com/ebaymotors/ws/eB...6476&viewitem=
H4 lights - http://cgi.ebay.com/ebaymotors/ws/eB...ht_4170wt_1190
Old Feb 12, 2009 | 03:24 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
Thanks. Do you only need one harness for both HID's?
Old Feb 12, 2009 | 06:30 AM
TheMuskr's Avatar
Re: HID's????
Nope just one harness. it goes from the battery to your ballasts. and it has a plug for the stock headlight plug so when you turn your lights on it puts power to the HID's.
Old Feb 12, 2009 | 01:17 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
Thanks again for the info.
Old Feb 12, 2009 | 04:15 PM
TheMuskr's Avatar
Re: HID's????
Yeah no problem. Let me know if you have anymore questions
Old Feb 13, 2009 | 11:34 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
Will do.
Old Feb 23, 2009 | 11:28 PM
RiggsLW81's Avatar
Car: 1987 IROC-Z Camaro
Engine: 350 (5.7L)
Transmission: 700R4 (Auto)
Re: HID's????
can this be done to stock iroc foglights? i plan on doing this but want the fog light color to match the low beam color...
is is exactly the same or? any help is appreciated..
TheMuskr...so your total investment was around $90 for all equipment? did you do your high beams or just the low beams?
Old Feb 24, 2009 | 11:53 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: HID's????
Should be able to put HID's in the fogs too. The stock bulbs in those are 885's, but I believe any 88x bulb kit will work since I remember seeing 880/881 kits. The difference in the different numbers looked to be if the plug on the bulb was straight or 90 degrees and different wattages.
Old Feb 24, 2009 | 05:36 PM
TheMuskr's Avatar
Re: HID's????
If you get the correct bulb size i dont see why it wouldnt work
Old Feb 24, 2009 | 05:50 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: HID's????
hey guys that link for those headlights, is that for only 1 headlight or is it for a pair of them? and are those low beam or high beam? is it a sealed beam headlight or does it have interchangeable bulbs? plan on doing this soon
Old Feb 24, 2009 | 10:34 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Re: HID's????
bulb light # is listed as 885 for iroc fog lights
will an 880 or 881 be compatible/fit??? i cant find a HID kit for 885 bulbs.. only 880 or 881... please advise!
thank you
Old Feb 25, 2009 | 09:57 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: HID's????
Read my last post
Old Feb 25, 2009 | 12:29 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Re: HID's????
got it...thanx.. i cant seem to find the difference between the 880 and the 881 kit (like wattages/ what the shape of the bulb is)
does anyone know? i want to order this stuff this week... but it has to be right, most of these kits are not returnable.
just need to know which kit: 880 or the 881 HID kit is correct for putting HIDS in the stock iroc foglights.
thank you
Old Feb 26, 2009 | 01:00 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Re: HID's????
anyone?
Old Feb 26, 2009 | 01:47 PM
krisb410's Avatar
Re: HID's????
800 series bulbs are identical, except for the actual plug. So as long as you adapt the factory plug to the HID kit you end up buying, you'll be ok.
Old Feb 26, 2009 | 02:50 PM
Ca[maro]88's Avatar
Re: HID's????
so can anybody tell me how many lights you get in that ebay link right there? i see somebody bought them and i plan on buyin them to. and are those lights dims or brights? im a little confused on that..
Old Feb 26, 2009 | 04:08 PM
RiggsLW81's Avatar
Engine: 350 (5.7L)
Re: HID's????
krisb... what do you mean by 'adapt the plug' is this something ill have to rig up, or just an alternate plug to purchase.? if so, which one..?
Old Feb 26, 2009 | 06:28 PM
krisb410's Avatar
Re: HID's????
Either, whatever you want.
Old Feb 27, 2009 | 12:51 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Re: HID's????
That auction is for just 1 headlight. The headlight can be used for either the bright or the low beam as it doesnt come with a bulb. Look around on Ebay, there are auctions for a complete set of lights. Both low beams,both brights,both foglights, and both clear corner lenses.
Old Feb 27, 2009 | 12:57 AM
Ca[maro]88's Avatar
Re: HID's????
thanks for the clearification.
Old Apr 29, 2009 | 07:43 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: HID's????
here is a post that should help
https://www.thirdgen.org/forums/elec...ml#post4050593
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Fronzizzle
Aug 19, 2015 01:36 PM
F-Body Tim
Aug 20, 2004 09:40 PM
CrazyHawaiian
Oct 1, 2003 09:41 PM
MrDude_1
Jul 12, 2003 06:04 PM
