92 rs vss buffer box
Old Mar 18, 2009 | 01:02 PM
yetterben's Avatar
Where is it? looked near ecm dindt see it. look under drivers side notta where is this sucker.
Old Mar 18, 2009 | 03:26 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 92 rs vss buffer box
You looked in the right place, near the ECM.
Is your engine TBI? Only TBI models had the yellow VSS buffer box.
Hope this helps.
Lou
Old Mar 18, 2009 | 03:31 PM
yetterben's Avatar
I foud it its white on mine.
Old Mar 19, 2009 | 12:14 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Hope this helps.
Lou
so what did the tpi's have? none? cause i am in the middle of a swap and it has the vss wires purple and yellow going into the computer. just curious
Old Mar 19, 2009 | 08:54 AM
BigBadLou's Avatar
Engine: TPI
That's exactly right, the TPI computer can receive the signal directly from the VSS.
Lou
Old Mar 20, 2009 | 08:30 PM
bwalo's Avatar
Car: Trans Am 1986
Engine: 305 H.O. Carb
Transmission: Auto 700R4
Can you provide pictures?
I changed my VSS sensor, didn't solve my problem.
I'm now looking, according to numerous threads, toward this VSS Buffer module.
Would be of great help.
Old Mar 21, 2009 | 09:55 AM
bwalo's Avatar
Car: Trans Am 1986
Someone can help me with what I'm looking for?
That damned VSS buffer box, where is it?
Is it deep under the dash?
My speedo hasn't worked for too long now...
Need some hints please.
Old Mar 21, 2009 | 10:55 AM
BigBadLou's Avatar
Engine: TPI
Bwalo, I am not 100% on this but didn't the 86 carbed cars use a mechanical speedometer? Then you wouldn't have a buffer box (which is normally under the passenger dash, by the ECM).
Lou
Old Mar 21, 2009 | 01:34 PM
bwalo's Avatar
Car: Trans Am 1986
Lou
Thank you for feedback. I believe 1986 was a year of transition on many aspects... There were carbed models, like mine, and TPI was also introduced in these cars that year, from what I've read... I also tought it was a mechanical speedo, but went to a mechanic and he told me it was electronic... no cable runnin' under the car (at first i tought the cable was broken at some point). The year after, went for the VSS change... didn't solve it... so i'm pretty sure mine is electronic... Althought, might not be the stock system (Car has 23 years, so... did someone mess in there in 1998?)
Anyhow, what I'm looking for is a general picture of location... I don't want to open the dash/cluster/instruments at this point. Thought it might be less painful/costly to do so (buffer) before attacking the speedo itself... I understand it may depend on model and year, but I'm pretty sure it's all +/- the same spot on 82-92 F-body equipped with the yellow/white buffer box.
Well, thanks again for your comment.
Last edited by bwalo; Mar 27, 2009 at 06:00 PM. Reason: Je parle en français et j'écris parfois des conneries en anglais parce que je suis pas habitué d'écrire en anglais tsé
Old Mar 29, 2010 | 06:43 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
so i did a conversion from tbi to tpi .do i need to remove the buffer box to get my speedo to work ???cuz it dont
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
