Fuses connected to battery cable...
Old Apr 30, 2009 | 06:05 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
Are they important and what do they do???
Old Apr 30, 2009 | 06:38 PM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Re: Fuses connected to battery cable...
Have you followed the wires to see where they go? Likely an aftermarket stereo or amplifier. Fuses are designed to protect your equipment and prevent fires in case of a short circuit.
Old May 2, 2009 | 03:57 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
i have yet to do that. there is an amp in it but not sure if it works. the cable is hot and the fuses keep blowing when i try to put in new ones
Old May 2, 2009 | 05:14 PM
Car: 87 IROC-Z
Engine: 5.7 TPI
Ok. What "Doesn't" work when the fuse blows?
Old May 2, 2009 | 08:36 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Is it a fairly thin red wire? $100 says it runs to that amp.
Old May 8, 2009 | 01:37 PM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
everything still works when it blows
not really thin but it is red
Old May 8, 2009 | 02:33 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I have this also, they are about 1/8" thick. This is for a stereo hookup for the amp. My radio works without this hooked up, so I figure it went to the amp and speaker the PO had in. It has a little housing it goes into, fuse is most likely a 30amp right? I have to agree, this is most likely speaker wire. Mine runs through the passenger fender with all the other wires making it some what confusing at first. I plan to remove all this extra wire when I do my new floor pans, carpet and seats.
Old May 8, 2009 | 03:13 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Like the guys said, you'll need to follow the wire to its destination. If it's powering that amp, there's a chance that the amp is blown or miswired.
Lou
Old May 10, 2009 | 09:46 AM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
ok so if fuse blows when i put a new one in the amp is blown?
Old May 10, 2009 | 10:49 AM
BigBadLou's Avatar
Engine: TPI
When you put a fuse in and it blows, whatever is connected to the end of the wire is bad. Or the wire is touching ground somewhere. That you will have to find yourself.
Lou
Old May 10, 2009 | 01:42 PM
Car: 87 IROC-Z
Engine: 5.7 TPI
If everything still works when it blows then don't bother replacing the fuse. You're just wasting your money. Cut it off and leave it off.
Old May 11, 2009 | 10:57 AM
19Maro91's Avatar
Car: Camaro
Engine: 305 TBI
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
