No Power After First Start Up
Old Jul 6, 2009 | 12:14 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
I have a 1986 trans am 305 tpi been sittin for 5 months while i did a lil bit of tune up stuff for it and when i just get about to start it it only started to crank for a second then nothin no accessories or anything looked in my fuse box and nothin popped ima get under and look for a short or anything but any suggestions would be a help
Old Jul 6, 2009 | 12:28 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: No Power After First Start Up
If it's sat for 5mths and not run I would charge the battery first and see if that does it cause a battery will discharge over time .
Old Jul 6, 2009 | 12:42 PM
fully charged up the night before
Old Jul 6, 2009 | 12:45 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
How are the connections at the battery and starter and the junction block ?
Old Jul 6, 2009 | 12:51 PM
they are all nice and tight is it could i have my starter hooked up wrong and blew a relay or fuse
Old Jul 6, 2009 | 12:59 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Possibly , I would check to be safe .
Old Jul 6, 2009 | 02:22 PM
is there a certain order that goes on the bigger bolt and which color goes on the smaller one jus wanna make for sure i got it right
Old Jul 6, 2009 | 02:29 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I believe it is purple for the small bolt on the solenoid and the others just go on the big bolt .
Old Jul 6, 2009 | 03:18 PM
there is no certain order that they go on
Old Jul 7, 2009 | 12:02 AM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
With a multimeter, test the battery voltage with the ignition on.
If the battery is good and you have a full charge, it should read 12 something volts with the ignition on. (Load on battery.)
Also you should be able to turn on your headlights and they should be bright without the engine running.
If you're not getting 12 volts with the ignition on and the headlights are dim when turned on, then there is a battery or other electrical problem.
Old Jul 7, 2009 | 09:23 PM
it aint the battery is there a fusable link that would break that would make it so that no power would go thro my car...jus a thought
Old Jul 9, 2009 | 09:08 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
There could be one comeing off the starter or one off your battery cable .
Old Jul 9, 2009 | 05:36 PM
on my wire diagram i have two that cos off my battery one goes to the ignition switch first then the second goes to the generator
Old Jul 10, 2009 | 07:55 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Check those and see if there is anything wrong with them .
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
