Help on my BERLINETTA
My 1984 Berlinetta's Speedometer and tach has pooped out while driving. Fuses are ok. and now I am at a stand still the Haynes manual does not show the wiring to these two gauges. Let me know before I get a can of gas and a match.
P.S. for those of you who like this cluster, it is nice, WHEN IT WORKS!!!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash Gash
If they failed simultaneously check for a break in the printed circuit board supplying power behind the dash.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsFog lights are not driving lights. They look doofy. Turn em off slow pokes.
Re: Help on my BERLINETTA
The instrument cluster in the Berlinetta is COMPLEX. Contact this guy. He can help. http://www.berlinetta.info/
If your dash has died he can possibly repair it or sell you one that has been repaired.
If your AC/Wiper Control pod has buttons that have to be pushed hard or wiggled to make them work I can restore it. Contact me @ gmjunkyard@live.com
ok so I bought another cluster today for my berlinetta and it still isn't giving me a speed or tach. I took the black cover off and the new cluster has the burnt marks in the same corners. Do these marks mean the LCD is burnt out or is this a regular thing. I need help please somebody!!!!!!!
Not sure as to why you have no speedo or tach. Might be the VSS. Contact this guy and he can help.
His name is John and he knows all about Berlinetta's. It might take him time to get back to you but be patient cause he will know.
ok here is some pictures of the two dashes that I have installes I am trying to find out if these black spots are suppose to be there or not. Both clusters have the black dots on them. The spots on both clusters are in the exact same place. So I really don't know if it is suppose to be there or not. JOHN PLEASE HELP ME!!!!!!!!!
Original Cluster
Cluster out a donor
Original Cluster
Cluster out a donor
I believe those are the marks left behind when the display was manufactured. The air inside the glass enclosure is vacuumed out and replaced with an inert gas like argon. Those are the marks left behind when it was sealed. I might be wrong but all my experience tells me that is what it is. I don't have a cluster open right now so I cannot verify this. I still believe your problem is outside the cluster.
so much. That helps a ton. Now do you have any idea which wire in the harness supplies the power to the speedo and tach. I figured they come out of the ECM but the Chilton Manual that I bought says nothing about the cluster for the berly. Joined: Jul 2002
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Signal should be sent over by the yellow box, it's called the speedo buffer, it splits the signal among the ECU, guage cluster, cruise control, ect. That shouldn't kill the tach though.
gimme a little time this evening and I'll try and dig one out of my pile. send me your personal email addy and I'll mail the photo directly to you.
I'm gmjunkyard@live.com
MM
MM
Hey Mike I will save your email but guess what I found it. The connector is half way hanging out so I plugged it back in and hooked up the old cluster.... No luck there. so I hooked up the donor cluster and boom there it was my speedo and tach was back. Now only if I new where all of those screws went....lol Hey thanks you soooo much for your help..
Thanks Again,
Trevor Long
www.kwondo.org
Thanks Again,
Trevor Long
www.kwondo.org
wow, i was right. Suprised, i don't see why that has anything to do with the tach. I could understand the speedo. Well i'm glad that got you back up and running. I wish you luck with your berlinetta, they are neat cars.
Jon
Jon
Dude who knows. It's a berlinetta. You hit the dash just right and that rough idle will go away. I probably hit another wire while I was down there. Who cares it works right. lol I spoke to John in RI and he said that when one goes they both go so maybe the speedo shorted out and the tach went with it. oh well Thanks a ton guys and I hope this will help another Berly owner in the Future. Also I have a friend that makes closeout panels that go under the hood and he is in the mist of making one for the third gen. Here is his URL http://www.undercoverinnovations.com
Car: 84, 85 Camaro Berl. 1999 Corvette.
Engine: 305, 400, LS1 350.
Transmission: 700R4, 700R4, 6 Speed manual
Axle/Gears: Factory
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If you're talking about John in RI you can send him a PM from here:
https://www.thirdgen.org/forums/member.php?u=884
Axle/Gears: Factory
Linson
Oct 1, 2015 09:50 PM
manifoldsrme
Sep 17, 2015 11:40 PM
1984, 84, 85, ac, berlinetta, camaro, control, dash, fuses, httpwwwberlinettainfo, manual, oweners, repair, speedometer, troubleshoot, troubleshooting, wiper
