wiper motor question
Old Dec 4, 2009 | 03:48 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
ok so a few weeks ago i noticed my windshield wiper wasn't working right (it would wiper 1/2 way). so i took it off to see if i could see what was wrong. i saw that the black plastic looking screw (holds that blue plastic piece and the circuit board together) was all messed up so i went to lowes to look for a replacement but couldn't find one so i ended up getting a new wiper. well the problem i have is that when i took it out, it didn't have that plastic housing with the circuit board and all that, all i saw was a gear with glue stuff on it. Isn't it supposed to come with everything or did i get ****ed... thanks for you your help.
Old Dec 4, 2009 | 10:47 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: wiper motor question
no your supposed to use your old stuff though if its an earlier year that electronic stuff is included with the washer pump if you really wanted it to be new.
Old Dec 4, 2009 | 11:14 PM
0pyders's Avatar
but my old stuff is broken. lol.
when i bought a washerpump it just came with the pump...not the circuit board and all that.
Old Dec 4, 2009 | 11:18 PM
What year is it? Is it the standard system (just off low and high) or does it have all the optional delay/variable speed control?
Old Dec 4, 2009 | 11:31 PM
0pyders's Avatar
1986 firebird with delay. 2 terminal
Old Dec 5, 2009 | 12:09 AM
Hmmm thats interesting i see what you wean about the cap and all not coming with it. Im sure someone else will pipe in with an answer of where to get one besides the junkyard and ebay.
Old Dec 5, 2009 | 11:26 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I just did the same thing, the circuit board is for our intermittent wipers and washer pump. I looked every where for a replacement and the only place I found one was on Ebay for 99.00. With out it you will just have high speed for wipers and no washer pump
Old Dec 5, 2009 | 11:31 PM
572_Rat's Avatar
Maybe you can do me a favor, which side of the pump is connected to the washer fluid container, firewall side or engine side
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
slade5612
Aug 11, 2015 07:19 PM
