Firebird/TA Instrument Panel Template
Old Jan 8, 2010 | 04:56 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I am putting Autometer guages in the 86 Firebird. I need to cut an instrument panel however I nee a template. Does anyone have one or know where I can get one?
Old Jan 9, 2010 | 02:49 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
Re: Firebird/TA Instrument Panel Template
dont have a template
but i do have an aluminum panel
its drilled for 3 3/8s speedo and tach and 2 1/16th volt fuel oil water gauges.... it was cut for the 85 up firebird dash, and wont fit correctly on my 84, got it on ebay for like $50 make me an offer it will probably be yours
Attached Thumbnails Firebird/TA Instrument Panel Template-hpim0726.jpg
Old Jan 9, 2010 | 03:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
whenever I get the plate back from my buddy who is milling another one, i have this one to mount the gauges right in the factory pod with no cutting of the dash involved. Its a really tight fit, but it works.
you need to pack the speedo and tach up about 1/2", they are a little off cented in the pic but they straighten out.
when i get time im going ot make a revised one to eliminate the spacers, probably ditch the smaller ones and just blank them off, then mold a pod intot he dashpad to hold the smaller guages.
Old Jan 9, 2010 | 04:09 PM
wretched737's Avatar
Me and my buddy were planning on doing something similar but i was just gonna make a whole new cluster, little easier on a camaro i think
Old Jan 9, 2010 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you can actually buy a aftermarket gauge bezel for a camaro, nothing available for the birds
Old Jan 11, 2010 | 01:05 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Both those layouts are similar to what I want to do. However I want it to look as Factory as possible. I have seen the Camaro set ups on Hawks. What I have currently is the Big twin hole set up with a bunch of idiot lights to the right. I really want a whole uncut dash. (I was just going to make one out of Fiberglass) or possibly clear cast. I also am looking at a 2 and 4 set 3 3/8s tach and speedo, 4 2 1/16 guages. I am going to try Classic Dash. They have first and second gen but no third, prices are rediculous too.
Old Jan 12, 2010 | 07:53 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Depends on what you want to do. I liked the look of the larger 5" gauges, so I modified the factory panel to fit them. My writeup is here. This was the final result:
This is the template I used for the (5) 2-1/16" gauges:
If anyone wants to do the same, I can email the .pdf of the template so that it is 1:1. Then I just printed it out, taped it to a piece of abs, and cut it out.
Old Jan 14, 2010 | 06:28 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Your Panel resembles mine, you just cemented the ABS behind the oval you cut out where the idiot light holes were? Interesting. You didn't use any of the factory senders other than the fuel gauge I take it.
Old Jan 15, 2010 | 09:29 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Actually, I mounted the oval flush with the panel and epoxied it in place. It took some more time to get it to fit perfect, but I think it has a cleaner look.
The fuel level, tach, and power wires were the only factory wires that I reused.
Old Jan 20, 2010 | 07:35 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Did you remove the panel behind the front panel entirely?
Old Jan 21, 2010 | 07:30 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes.
Old Jan 21, 2010 | 05:54 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Looks like the way for me to go. I would like to start with a pristine piece though. Mayble I can make one from clear cast or fiberglass.
Old Aug 11, 2015 | 12:12 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Axle/Gears: Moser 9" 3.70 Wavetrac
If you still have the template pdf please email to stangty@ae.ca
Thank you kindly
Old Aug 11, 2015 | 01:20 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Thank you kindly
Email sent.
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
