Buzzy noise under the rear of my 88 iroc-z 350 tpi
Old Apr 9, 2010 | 12:43 PM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
Hi GUYS!! thank you all for this useful and beautyful forum; it's a bible for me here in Italy because nobody knows american cars!!
Can somebody tell me what the buzzy noise under the rear of my 88 iroc-z is?
it starts when i turn the (hot) engine off and goes on for 5/10 minutes.
thanks
Manuel
ITALY
Old Apr 9, 2010 | 12:53 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Re: Buzzy noise under the rear of my 88 iroc-z 350 tpi
thanks
Manuel
ITALY
It's like a humming sound right? It's the pressure in the gas tank...if you remove your gas cap, it releases the pressure and goes away. It comes back within seconds on my car as well. I was told that it could be the tank pressure check valve but I'm not sure yet.
Old Apr 9, 2010 | 01:21 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
does it do that on all of our cars? or is there any way to stop this completly?
Old Apr 11, 2010 | 05:07 AM
asfalto's Avatar
yes, it is a humming noise.. i'll check ASAP if removing the gas cap it stops and i'll let you know!!
thank you LS7Roc!!!!
Old Apr 12, 2010 | 06:04 PM
Pocket's Avatar
Car: 91 Trans Am
Fuel pump whine. Perfectly normal
Intensity is dependent on which pump is installed and the age of the unit
Old Apr 16, 2010 | 04:32 AM
asfalto's Avatar
So, LS7Roc is right!!!!
after i turned the engine off the humming noise starts.. and ends if i open the gas cap; then closed starts again after 5 minutes...
Is it all about pressure and vacum, right?
When Pocket says it is the fuel pump whine he doesn't mean something electrical?
thank you ALL!
ciao
Old May 29, 2014 | 12:51 PM
asfalto's Avatar
I've noticed that, if I loose just a little bit the tank cap, the whine never come on and, more important, the car run much better.
Is there any contraindication if I drill a very little hole in the cap to not let the tank go under pressure?
thanks
Old May 29, 2014 | 12:58 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
thanks
NO DRILLING IN THE CAP!!!!!!!!!!!! If it runs for THAT long after shutdown, you might have a F/P relay bad. It should last maybe 5 seconds or so; NOT 5 minutes
Old May 30, 2014 | 07:23 AM
If it sounds about like something under the car is blowing its nose every minute or 2, then it's probably the vent valve aka "UFO".
Create the conditions that cause it to happen. Jack up the left rear and remove the tire. Just inside of the front LCA bolt, you'll see a white plastic thing maybe 60mm diameter. See if the noise is coming from that. If so, you need a new one. Sorry, no idea where/how to get one.
Old May 31, 2014 | 01:57 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Is it normal for that much pressure to build up in the tank? Mine seems to have a lot of pressure.
Old May 31, 2014 | 08:07 PM
Pocket's Avatar
Car: 91 Trans Am
Get a vented gas cap or replace the vent
Old Jun 4, 2014 | 12:19 PM
asfalto's Avatar
It is not an electric problem! when I shut the car down the pump shuts off correctly.
It'is only about pressure/vacuum building up in the thank I guess..
Old Jun 4, 2014 | 12:23 PM
asfalto's Avatar
Can i get the same effect by drilling a small hole in the cap?
Sorry but here in Italy is not so easy to find the correct parts..
Old Jun 4, 2014 | 07:30 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
I can't find the vent on my car. I do see a line at the driver side rear wheel area that has a rubber cap on it. I'm guessing that's where the vent goes.
theshackle
Sep 17, 2020 08:26 AM
1nastygta
Oct 28, 2015 08:51 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
