no headlights and radio
Old Jun 4, 2010 | 09:15 AM
jwa1984's Avatar
Car: 1984 camaro
Engine: 305 v8
Transmission: 3 spd auto
Hi there I just put a v8 from a 1982 tans am into mt 1984 camaro and now the motor is running great but I have no headlights and the dash lights and radio are not working I know I must be missing a power or ground any ideas would help out thanks.
Old Jun 5, 2010 | 01:12 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: no headlights and radio
Stupid ?, but did you check to see if you blew some fuses?
Old Jun 5, 2010 | 02:25 PM
jwa1984's Avatar
Car: 1984 camaro
Engine: 305 v8
i did check that i all so rechecked if the the cable to the starter were hooked up right and they are. so I have no clue what is going wrong. it has to be a main ground or power that the 1982 trans am did not have that the 1984 camaro needs
Old Jun 5, 2010 | 04:14 PM
travis401's Avatar
Car: 91 Camaro RS
Could just be differences in the pin out of the c100 connector. Id get a pin out of the stock one and one of the trans am harness and compare.
Old Jun 6, 2010 | 04:10 AM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
check that and check ur fusible links maybe u blew one by accident they are those like cylindrical plastic things on the main big wires going to the fuse block they are pretty close to the starter u prolly already seen them check for power after them (between the fusible link and the fuse block) if burn get a new one at autozone and swap them good luck
Old Jun 7, 2010 | 08:46 AM
jwa1984's Avatar
Car: 1984 camaro
Engine: 305 v8
I did check for power at the fuse box from the links and alls good but still nothing. thanks for the idea
Old Jun 7, 2010 | 08:48 AM
jwa1984's Avatar
Car: 1984 camaro
Engine: 305 v8
I will check that tonight hope that will be all that it is thanks
Old Sep 15, 2010 | 07:29 AM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Did you ever find out the problem with your radio and headlights? Mine does the same thing sometimes. Ill turn my headlights on and they will go out along with the dash lights and radio and then come back on?? Thanks
Old Sep 15, 2010 | 02:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is A Nite Club
If the headlights go on and off at regular intervals you might have a defective or overloaded circuit breaker in the switch.
The radio going on and off simultaneously is consistent with the radio dimmer circuit being mis-wired.
Disconnect the
brown wire going to the radio.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Sep 16, 2010 | 10:39 AM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Re: Car Is A Nite Club
Thanks for the help. I will disconnect the brown wire when I get home. Also last night I decided to drive my car. I pulled my headlights on and everything went out, horn, dome light, dash lights, radio speakers but I had power to the radio. They will usually eventually flicker and stay on but this time they didnt. I start moving wires around my drivers side kick panel and my dome light came on. Pulled my headlight switch and they went back off. Moved the wires again and it stayed on. Dumb question but does the vats have anything to do with this. I bypassed my vats when I did a carb motor setup. Also when I turn my key back the radio wont come on. Any help would be greatly appreciated. Thanks in advance!
Old Sep 16, 2010 | 11:59 AM
NINÅ's Avatar
Transmission: 765R4
Car Is A Nite Club
When you’re moving wires around and getting different results, it makes it sound like there’s a wire or two with rubbed thru insulation.
There might be loose splices made by the PO.
To find out where, you can temporarily bypass the problem with fused jumpers.
Once you find the problem route(s) you can redo that section of the harness.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
