Electrical Disaster
Old Jul 12, 2010 | 12:38 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
Electrical Disaster
Ok 1991 Camaro Rs.
5.0L 305. v8 Standard. LO3.
Problem: Car battery drains out while driving.
Tried Fixes: New Battery, new alternator, new distrubutor cap and rotor (Didnt change Spark Plugs dont know why)
Mods: Only thing changed that i think could affect it is Fan is on a toggle switch but shouldnt cause this bad of a drain if any.
MISSING!!! My Junction Block was removed and all the hot wires going to it were spliced together (Stupid friend did it)
So if anyone know what wires go to the Junction Block PLEASE let me know.
Also if anyone is in the DFW area in TX (I live between McKinney and Plano) and have extra time i would love to have a expert swing by and have a look at it for me. Thanks.
Old Jul 12, 2010 | 01:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Master Of Disaster
The wires that go to the junction block are:
Fusible link for the alternator.
Fusible link for the fan.
An inline fuse.
A wire from the battery.
Battery drain.
Sometimes the under-hood light does not go out so check that easy one first.
Then connect an ammeter in series with the battery.
If there is more than 50 milliamps there is excessive draw.
(You can use a small bulb such as a side marker bulb if you don’t have an ammeter.)
With everything turned off and doors closed observe the current flow.
Pull the fuses one at a time till you see the current drop.
That’s the circuit with the problem.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 12, 2010 | 01:39 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Re: Master Of Disaster
What do you mean by an "Inline Fuse" and the Fusible Link from the alternator is just the Thicker hot wire right?
And to find the drain, Where would i connect it exactly, in series means very little to a non-electrical engineered brain.
Old Jul 12, 2010 | 01:40 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Also is there a place where i could order a new Junction Block?
Old Jul 12, 2010 | 04:00 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Electrical Disaster
JY or I can send you one for $10
Old Jul 13, 2010 | 09:03 AM
NINÅ's Avatar
Transmission: 765R4
Master Of Disaster
The inline fuse is a bayonet fuse holder with a 20 amp fuse.
The link is a looks like a black plastic cylinder molded onto the wire.
In series means you must disconnect one wire on a circuit, and put another device between the disconnection.
Therefore you must connect the ammeter or test light between the battery and battery cable.
Happy Racing!
How Come I Drive 400 Miles Most Weekends And Windup Where I Started?
Old Jul 13, 2010 | 12:34 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Ok welll that kinda helps but im still not getting the big picture here.
So the fusible link is just any wire spliced on to the alternator wire that is ran the the junction block.
The inline fuse i should go buy a bayonet fuse holder and run the wire thru it then to the junction block? But which wire/where is the the wire that needs this inline fuse supose to come from?
Old Jul 13, 2010 | 12:35 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
If you could pictures are better then a 1000 words.
Old Jul 13, 2010 | 03:14 PM
NINÅ's Avatar
Transmission: 765R4
Master Of Disaster
Not any wire.
It’s a short piece of wire encased in a nonconductive enclosure.
The short piece of wire is a smaller size therefore will melt first thereby saving the harness from melting.
Because you need the junction block you should get one from
Pocket in post #5.
Yes.
That fused wire starts at the junction block and passes power to the fuel pump and ECM.
Hopefully someone will have time to take and post a photo of the area.
Happy Racing!
Old Jul 14, 2010 | 06:38 PM
Jays92Camaro's Avatar
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
here is a photo of a removable fuse link. I will send a photo of the other white 1 inch long in-line cylinder type when I can get to one.
Attached Thumbnails Electrical Disaster-img_0132.jpg   Electrical Disaster-img_0133.jpg
Old Jul 15, 2010 | 10:38 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
If you could, could you send me it?
Just toss me a email.
Old Jul 17, 2010 | 02:55 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
See this thread for a photo of the in line fuse for the under hood lamp in an 82 Camaro. The in line fuse will look almost the same no matter what year your car is.
The picture is in Message #8
https://www.thirdgen.org/forums/elec...nder-hood.html
Last edited by 82CrossFire Z28; Jul 17, 2010 at 02:55 AM. Reason: Added link to thread
Old Jul 17, 2010 | 12:35 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
is that all the inline fuse that goes to the Junction block is for? The Underhood light?
Old Jul 18, 2010 | 02:05 AM
Best way to find the answer to that question is to physically trace the circuit. In my 82 there are two in line fuses, one from the battery to the ECM and the other is from a tap in the blower motor high speed circuit to the Under hood lamp.
I don't have a 91 so I cannot confirm that. However if there is an inline fuse, it usually serves a load that is put on the car as an option. Then GM could just add the circuit and power it from an availabe power tap. The in line fuse just protects the circuit it is in. The point of the power tap usually has an amacity rating greater that the wire to the option add on can carry, so they put a fuse in line to protect it.
Old Jul 20, 2010 | 08:33 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
ok i think i understand more on what to do now,
Just waiting on Pocket to send me my Junction Block.
Where can i pick up a Bayonet fuse holder? Autozone?
Old Jul 20, 2010 | 10:23 PM
Yes, any of the Auto Parts stores will have the fuse holder and fuses in the electrical parts section. Note that the fuse holder usually comes in a blister pack and only has a pigtail of 3"-6" on the ends of the fuse holder. You will need to get a few weatherproof connections to make up the connections, likely some wire to connect to both the junction box and the light and a ring terminal to connect the wire to the junction box. The ring terminals are usually a compression type, you put the bare wire in the compression tube, and compress it with a special tool. The tool will cost in the range of $15. - $20., and it may be a bit less. make sure the hole in the ring terminal is big enough to fix on the junction box
Old Jul 21, 2010 | 03:56 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Should be fine as to I dont think im going to lose that much wire when connected.
What light are you talking about? The underhood light that is also powered by the junction block?
Good advise, already have the crimper tool and ive made that mistake before of not checking to make sure the ring diameter was big enough to fit.
Old Jul 22, 2010 | 09:33 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Ok just got my Junction Block in the mail, Thank you Pocket.
And went to start connecting all i could.
The wire with the yellow circle on it is my alternator wire, used a fuseable link wire on it.
There was a hotwire (red circle )that ran deeper into my engine bay, since it wasnt my battery wire or my alternator assumed it was the one that needed the Inline fuse. Its looks a little off from what i thought it would be. But i also have a differnent wire which i believe to be the right one.
Then theres my battery wire (light blue wire)
And im not quite sure what the (pink) circled wire goes to anymore off the top of my head. But theres also my fan wire which isnt connected yet.
Did all this and went to start my car, theres power it just wouldn't crank on.
Old Jul 23, 2010 | 06:22 AM
Pocket's Avatar
Car: 91 Trans Am
Did your fuel pump prime? The fuel pump/ECM 12v constant fuse isnt mentioned
Old Jul 23, 2010 | 08:55 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Umm im planning on checking for the 12v today.
Im just hoping I didnt let my battery charge up enough is why it didnt turnover.
How would i check if my fuel pump primed?
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 05:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
