Car won't always start first try.
Old Jul 29, 2010 | 01:08 PM
makiguy's Avatar
So I'm assuming this is an electrical problem but occasionally when i turn the key it won't start and sounds like the batteries dead. I turn it a few more times though and it will start right up. Its not always the case though as most of the time it will just start on it's first try. Anyone have any ideas as to what may be causing this?
Old Jul 29, 2010 | 03:24 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Car won't always start first try.
What make, model, year?
Old Jul 29, 2010 | 03:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It Will Always Start On The Last Try
Are you trying to say — it cranks slow — or not at all.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Jul 29, 2010 | 04:59 PM
makiguy's Avatar
Sorry it's a 1991 Camaro rs v6, Battery should be good still it's less than a year old and I wouldn't think it would start at all if the battery were bad.
Old Jul 29, 2010 | 07:09 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
As NINA is trying to get at, what do you mean by " sounds like the batteries dead" Tell us what happens. Is there any sound? Does the engine turn over slow, or not at all? Any clicking? When you are trying to start it do any of your gauges(ammeter) do anything?
Help us help you by giving more information. Thanks
Old Jul 30, 2010 | 01:05 PM
makiguy's Avatar
It won't crank at all. I turn the key it makes a click and then nothing. Didn't see if any of the gauges happen to do anything but when it happens next ill be sure to pay attention to them.
Old Jul 31, 2010 | 08:45 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Check your battery cables are tight and free of corosion
check your starter wires are tight
Old Jul 31, 2010 | 12:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: It Will Always Start On The Last Try
On this page there is a starter circuit diagnostic link.
There is also a link for wiring diags for almost all 3rd gens.
Could be an issue with your Ignition Switch (not the key cylinder), Starter Enable Relay, Neutral Safety Switch, starter wires, or any connection inbetween.
http://www.austinthirdgen.org/index.php?pid=2
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
