NOW what happened?
Old Jul 30, 2010 | 06:16 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
NOW what happened?
Ok a few weeks ago my interior light mysteriously went out, i though it was strange because not to long ago i replaced the bulb, but i had an extra and replaced it but it do anything so now that doesnt work. then i noticed one day my power mirrors didnt work, i belive it was after having the interior light crap. now today i noticed my power locks dont work either. And this is on both doors. What is up? Im guessing all these things took a crap at one. It seems all my other electronic stuff works but its just the locks/mirrors/interior dont. What happened!?
Old Jul 30, 2010 | 06:54 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: NOW what happened?
check your fuses man, i think all your problems are on one fuse iirc
Old Jul 30, 2010 | 07:32 PM
Engine: 305TPI
also forgot to say my radio also wont hold stations, like if you set your stations then turn off the radio it delets them all.
is there a specific fuse i should check? thanks
Old Jul 30, 2010 | 07:40 PM
Engine: 305TPI
well i looked and i dont belive anything are missing exept number 15 which is for the hatch motor which was tooken out because it was killing the batt. but i pressed on all and none felt lose and i checked everything again and nothing. what fuse could it be?
Old Jul 31, 2010 | 03:23 PM
Engine: 305TPI
anyone else?
Old Jul 31, 2010 | 03:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You will probably also find out that your horn and third brake light and lighter don't work. These are all on the same fuse as all the other stuff. Same thing happened to me . I found the blown fuse, but every time I put in a new one it blew immediately. Turns out the lighters like to short out sometimes. If your fuse blows when replaced, disconnect the lighter from behind and then try putting in a new one. If all is OK, replace lighter or leave unplugged. Good luck
Old Jul 31, 2010 | 07:14 PM
Engine: 305TPI
thank you! do you happen to know what fuse it was?
Old Jul 31, 2010 | 07:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I can point it out on my car, but yours is different. Do a search on here, I know I've seen yours shown somewhere. Otherwise, just take out fuses one at a time until you find the bad one. Not sure if it will solve your problem, but it worked for me. Happy hunting
Old Jul 31, 2010 | 07:53 PM
Engine: 305TPI
what does a blown fuse look like? thanks.
Old Jul 31, 2010 | 08:05 PM
Engine: 305TPI
well i took out all of them one at a time and none, from what i could tell look diffrent from others. i dont even know what i should put in the search box lol.
Old Jul 31, 2010 | 08:18 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Your fuse should be a yellow 20amp, might say curtousy or radio. The fuse should be a clear yellow, in the center it is a S shape, if it's blown it will have a break in the middle. Like another post said, the cig lighter is the most common culprit. Disconnect from the back of the lighter and tape the wire end with electrical tape. To try to find a nice working lighter is damn near imposible. Good luck.
Old Jul 31, 2010 | 08:35 PM
Engine: 305TPI
thanks, well i found several that had the v shape in the middle and then there was a orange 5 fuse that has an S, i did go thru all of them this time but i only found one fuse with an S.
Old Jul 31, 2010 | 08:40 PM
Engine: 305TPI
ok, found the flippin fuse! what do you mean by the back of the lighter? its never pushed in i always leave it nearly falling out am i fine doing that? Thanks!
Old Jul 31, 2010 | 08:42 PM
red rock's Avatar
Car: 1987 iroc
Well V or S doesn't matter as long as they aren't burnt in two in the middle. Thats just the difference between two fuse manufacture's. The fuse's are color coded for the amps they can handle.
Old Jul 31, 2010 | 08:50 PM
Engine: 305TPI
ok, so what do i do about the lighter, i took out those 4 allen bolts and the lighter unit didnt move to much and i didnt want to force it and break it.
Old Jul 31, 2010 | 08:56 PM
red rock's Avatar
Car: 1987 iroc
There is a thin fillement in the bottom of the lighter socket that falls apart after time and shorts out the fuse. Take the socket screws off of the frame and pull out the lighter assembly and disconnect the power wire in the back. Trying to find a good working lighter socket is damn near imposible.
Old Jul 31, 2010 | 09:00 PM
red rock's Avatar
Car: 1987 iroc
There should be enough slack to pull out the socket. There is a plastic clip on the wire that will unsnap from behind the lighter socket.
Old Jul 31, 2010 | 09:02 PM
Engine: 305TPI
sorry im stupid at some things, is there a step by step (With pictures)guide on doing this or anything? i'll take a shot at it though later. Thanks!
Old Jul 31, 2010 | 09:06 PM
red rock's Avatar
Car: 1987 iroc
Your not stupid, it's always easier for someone that's done it before. You'll get it.
Old Jul 31, 2010 | 09:39 PM
red rock's Avatar
Car: 1987 iroc
Here's a pic of my old assembly.
Old Aug 1, 2010 | 12:08 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi again. You unscrew the four screws and pull out the panel with the orange and black wires attached to the clip on the back of the lighter. Pull back the plastic ears on both sides of the clip and it will pull free. You can just leave it unplugged, but the clip that was on the back of the lighter cannot be allowed to touch anything because the orange wire is hot with the key on. If you have found the fuse with the center part broken(melted apart) you can now replace it and your dome light should go on if this was really the problem. I've got several good lighters if you need one, that is, if this whole process succeeds. I only figured out this stuff by doing "research" at the JY and taking their cars apart. Seemed like a good idea?
Old Aug 1, 2010 | 12:22 AM
Engine: 305TPI
thanks guys! if i dont use the lighter (no need to) is their still a chance the fuse will crap again because of that problem? Thanks!
Old Aug 1, 2010 | 12:30 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The problem is not in the part that comes out. The part that goes bad is the piece it slides into. That has to be disconnected . If this fixes it and you don't replace the lighter it will never happen again . If you do replace it it could possibly happen someday, but fixing it would now be simple.
Old Aug 1, 2010 | 04:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi, did you find the blown fuse? Is it OK now?
Old Aug 1, 2010 | 06:15 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
OOPS, correction, the orange wire is always hot, key on or off
Old Aug 23, 2010 | 07:46 AM
Engine: 305TPI
sorry, i finally got ahold of an fuse and everythings good, atleast for now. Plus i got about 10 extras lol
Old Aug 24, 2010 | 08:51 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you know i have the same problem but my acc fuse is the one thats blown.... hmmmm i never thought to check the lighter. wish my manual had better wiring diagrams.
Old Aug 27, 2010 | 08:22 PM
Engine: 305TPI
finally got the fuse an few days ago, thankfully fixed everything. i just bought an 6 pack? of them so if the fuse blows again im covered lol.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
