A single green wire between the brake booster and the distributer where does it go to
Car: 89 T/A Blue/Gray T-Top
Engine: 5.7
Axle/Gears: 327
I have a single green wire that I dont know what it goes to. This wire is near the firewall between the brake booster and the distributer.
I think its c15 on the wiring diagram but that does really help me out as i still dont know where it plugs into.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: A single green wire between the brake booster and the distributer where does it g
I dont see the c15 ,but check your temp sensor sounds like it. One wire green. Sorry I see it now. Don,t know
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wires Add Weight, Cut ‘em All Off
Does anything not work on the car?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Happy Racing!
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
coolant temp sensor wire
Engine: 5.7
Axle/Gears: 327
Just found out that, That wire goes to my EGR temp sensor which my car does not have. Currently looking for one. Its not manufactured by anyone anymore.. Theres one on Ebay $180.00 and its a used one..Thats freaking crazy....
Thanks to all for your input.
i have the same wire...its hooked up to a coolant temp sensor...on the driverside head..(cheaper sensor)..good luck
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
and i might as well add my two cents.
its the coolant temp sensor wire.
it has nothing to do with the EGR
Engine: 5.7
Axle/Gears: 327
Here is one write up about that EGR temp sensor is about 10 pages long but its got lots of pictures and also very good info.
https://www.thirdgen.org/forums/show...ferrerid=66236
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Heres my 2 cents,
although the coolant temp sensor has a single green wire so does the the egr sensor your talking about. so it has alot to do with it. I also have the sensor for you.
