Check engine light help needed
Old Aug 15, 2010 | 04:56 PM
rabidcanadian's Avatar
My check engine light does not work at all. Cannot pull any error codes from the ecm. Turn the key to the run position and no check engine light. Any idea how I can go about fixing this issue?
Old Aug 15, 2010 | 05:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Check engine light help needed
Maybe the bulb is just burnt out.
Old Aug 15, 2010 | 06:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What year is the car and which engine does it have?
Old Aug 15, 2010 | 07:35 PM
Sorry should have added that the bulb is fine, doubled checked it, and even tried a new bulb.
Old Aug 15, 2010 | 07:36 PM
The car is a '89 Trans Am GTA with the 350 tpi. Analog dash.
Old Aug 19, 2010 | 02:42 PM
Any ideas?? Is there a way to check the circut for this function?
Old Aug 19, 2010 | 03:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Check This Out !
With the ignition OFF disconnect the ECM.
Using a fused jumper
(1 amp is good) ground pin A5 of the connector (not the ECM).
Now, turn the key to the RUN position.
Does the
Service Engine Soon light come on now?
Happy Racing!
Make Noise, Turn Left, Repeat
Old Aug 21, 2010 | 06:00 PM
Re: Check This Out !
K, tried that and it does not come on. Anything else to try or check??
When I disconnected the ecm I undid both connectors, was this the correct thing to do?
Old Aug 23, 2010 | 09:23 AM
NINÅ's Avatar
Transmission: 765R4
Check This Out !
That’s fine.
The purpose of disconnecting the connector(s) was to prevent damage to the ECM from voltage being applied to the wrong place when you were probing A5.
Due to the fact the
Service Engine Soon did not illuminate when you grounded A5 of the connector means there is a break in the connection to the bulb.
The break might be in the wiring, connector, or PCB trace
(difficult to see).
With the ECM still disconnected, remove the
Service Engine Soon bulb, then turn the key to RUN.
Now using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the bulb socket.
One side must have power.
Turn the key to OFF, then remove the bulb, and grab an ohmmeter.
Probe the other side of the socket with one of the ohmmeter leads, and the other lead to A5 of the disconnected ECM connector.
There should be one ohm or less in that circuit.
What are your results?
Happy Racing!
Engines Run Best Right Before They Blow Up
Old Aug 28, 2010 | 04:29 PM
Any idea what colour the wire is on the back of the dash for the check engine light? And would it be the upper or lower connector?
No power at all to the light socket.
Old Aug 28, 2010 | 04:56 PM
Car: 1992 RS
Engine: Carbed 350
http://www.austinthirdgen.org/mkport...uges_part1.gif
Old Aug 28, 2010 | 10:48 PM
Problem finally solved. Now that the problem is fixed I feel quite stupid, lol. Turns out someone had removed the bulb and socket and put it into a differant place, then taped over the spot for the check engine light.
So I removed the tape, placed the light in the correct spot and now it works like it should. And to top it all of no error codes.
3 weekends trying to sovle this and turns out to be something stupidly simple.
Anyways thanks for the help guys.
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
