car dies when the brake is released??
Old Sep 12, 2010 | 01:09 PM
kylemeadus's Avatar
Car: 25th Anniversary Convertible Z28
Axle/Gears: Stock
recently swaped trannys and now the car dies when in gear after the brake has been released. idles fine in park , nutral but will die in the other gears unless the brake is being pressed. my first thought was the tourque converter was locked up but i have the car on jacks stands without the parking brake, the tires should spin anyway if it is indeed the TC correct?. ive sence changed TCs just to be sure that is not the issue and the same problem still occurs(also tried unpluging the lockup connector). so i am now leaning twards it being an electrical issue. maybe i messed something up when pulling out the old tranny. i just dont know. any ideas would be greatly appreciated.
Old Sep 12, 2010 | 06:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: car dies when the brake is released??
Sounds like something with the neutral safety switch or the brake switch.
Old Sep 12, 2010 | 08:32 PM
kylemeadus's Avatar
Axle/Gears: Stock
well sence my last post it stoped doing that. now it dies when i give it gas with out the brake when rolling. if i power brake it it seems to do fine. checked the throtle possitioning censer and it seems to be fine. is there anything that can kill the fuel pump or injectors when i give it throtle without braking?
Old Sep 12, 2010 | 08:52 PM
blueberrycamaro's Avatar
Car: 89 camaro
Engine: 350 LT1
Transmission: 700R4 slushbox
My fiancé says:
Sounds like the TC is/was stuck on. With the car in the air, the TC can still stall it, there is A LOT of drag when it is engaged. After you replaced the TC, the solenoid was/is stuck sending fluid to the TC keeping it engaged. After unplugging the connector the solenoid, being stuck open, is still sending fluid to the TC causing it too stall. If possible unbolt the TC from the flex plate and push the TC back into the transmission, should move a few mm, to keep it from rubbing. Then see if the car still stalls. Probably going to be a bad solenoid or valve body.
Old Sep 12, 2010 | 08:56 PM
kylemeadus's Avatar
Axle/Gears: Stock
that was my thought at first as well but now i can put it in drive and roll at idle. as soon as i give it gas it dies and some times its lurches hard before it dies.
Old Sep 12, 2010 | 09:05 PM
Car: 89 camaro
Engine: 350 LT1
My fiancé says:
Still sounds like the TC. As you accelerate the transmission fluid pressure builds and leaks past a partially open valve and applies the TC stalling it out. Did it have this issue before you swapped transmissions? I doubt you would have pinched or pulled the harness, though that could also be a possibility. I'd check that as well. Though I still think it is in the new transmission...
Old Sep 12, 2010 | 09:27 PM
kylemeadus's Avatar
Axle/Gears: Stock
no it didnt. after i put the new one in i thought it was the TC so i pulled it out and put the old one back in knowing that it functions( i had lost 3rd and 4th in the old tranny). is there anything i can do without draining the system again? auuggg
Old Sep 12, 2010 | 10:00 PM
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Did you flush out the old TC before you put it back in? Not that this would solve your problem, but hopefully there were no metal shavings in the TC from your trans going bad. When your engine stalls. Is it acting like how a stick shift would taking off in a high gear like say 5th? I had a lock up solenoid go bad once and thats how it acted. The TC was locked all the time.
Old Sep 12, 2010 | 11:49 PM
kylemeadus's Avatar
Axle/Gears: Stock
i did flush it and it was clean. the car dies smooth as if it ran out of gas very fast its not vilent and the car will just coast.
Old Sep 21, 2010 | 05:27 PM
kylemeadus's Avatar
Axle/Gears: Stock
its all good now. thanks for the help. it turns out that the new trans has a different speedo pick up and every time i let off the brake the govoner was kickin in at 3mph. lol what a pain in the ***
Terrell351
Jun 13, 2021 01:13 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
