carb swap and lost my tach
Old Oct 30, 2010 | 08:33 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I swapped out motors from tpi to carb and now my tach does not work. I have a new msd hei distributor and plugged the white wire that was on the tpi coil into the slot on the hei Distributor labeled for tach. This is a 1990 camaro if that makes any difference. Thanks for any input.
Old Oct 30, 2010 | 09:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb swap and lost my tach
What's the distributor P/N?
Old Oct 31, 2010 | 10:09 AM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
part #8362
Old Nov 16, 2010 | 02:25 PM
KC85firebird's Avatar
i would like to know this also, i have same problem, do the factory tach hook up like a aftermarket?
Old Nov 18, 2010 | 06:53 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
As far as I know you plug the white wire into the distributor where its marked tach. BUT this will not work on my 90 Iroc, something must have ran thru the comp, and I deleted it. Maybe someone will chime in with the answer.
Old Nov 18, 2010 | 08:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Dustytrix
something must have ran thru the comp, and I deleted it. .
Tacho feed goes direct from coil or HEI to tacho.
White wire off coil to Instrument cluster in diagram
see
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Maybe you screwed up when removing computer wiring.
Find the tacho signal wire ( white ) at the dash plug and meter between that and the connector at HEI to see if you have a circuit.
If not you have a break in the wire somewhere
Old Nov 19, 2010 | 07:35 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks Vette I will ohm that out tomorrow, If that schematic came from the service manual what page is it?
Old Nov 19, 2010 | 11:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Someone has scanned all the engine pages and put them online
Should be in the circuit diagrams of your FSM
Infested
May 22, 2018 11:56 PM
midge54
Jan 29, 2017 07:00 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
stalkier
Aug 7, 2015 04:49 AM
