Tach Problem?
Old Dec 6, 2010 | 09:09 PM
ChrisJ91RS's Avatar
Car: 1991 Camaro RS
Transmission: Stalled 700R4
Axle/Gears: 3.23 Posi
Tach Problem?
Hello, Im new to this site and I just bought a 1991 Camaro RS that someone swapped a sbc 350 TBI into for $700 bucks. I am have a couple of problems but I would like to fix this first. The problem is that when I go to start my car the tach starts 7000rpm then hangs around 3000 when its trying to start, then after it starts the tach goes maxed out and never moves anymore. What should I check first. Thanks in advance.
Thanks, Chris
Old Dec 7, 2010 | 10:50 AM
Brads RS's Avatar
Re: Tach Problem?
was the car a V6 before? could have the wrong tach. Common problem with tach is the resistor network in the tach goes nutty this could also be your problem. First thing is i would have your cluster fixed/checked.
Old Dec 7, 2010 | 11:40 AM
ChrisJ91RS's Avatar
Car: 1991 Camaro RS
Re: Tach Problem?
Nope, it was originally a 305 in it. I decoded the vin.
Thanks, Chris
Old Dec 7, 2010 | 11:51 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Tach Problem?
https://www.thirdgen.org/forums/elec...meter-fix.html
Get a multimeter, pull the gauge cluster out, remove the clear plastic lens and gauge face surround from the cluster, and follow the instructions in the link above. The resistors in the tachometer circuit board go bad causing the exact problem you just described.
Old Dec 14, 2010 | 01:32 PM
ChrisJ91RS's Avatar
Car: 1991 Camaro RS
Re: Tach Problem?
Thanks, I will try it and see if it works
Chris
Old Dec 16, 2010 | 01:27 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Tach Problem?
Thanks, Chris
whether the engine was a 305, 307, 327, 350, or 383, the tach will always read the same. The tach signal is produced in the dizzy. The issue may be in the tach circuitry board. Ill post the link for you.
Old Dec 16, 2010 | 01:28 AM
Re: Tach Problem?
Its a sticky on this very board. Anyway, here it is https://www.thirdgen.org/forums/elec...meter-fix.html
Old Dec 16, 2010 | 09:33 AM
ChrisJ91RS's Avatar
Car: 1991 Camaro RS
Re: Tach Problem?
Chris
Old Dec 16, 2010 | 09:57 AM
Re: Tach Problem?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
