wont start
Old Dec 19, 2010 | 02:41 PM
dvardaman85's Avatar
Car: 1985 Chevy Camaro
Axle/Gears: 3.08
wont start
car turns over well but wont start. pink wire going into dizzy meters at 12.9v seems pretty good. getting fuel and timing has not changed since last started (unless it is magic timing). i have metered all of the wires, coil, (accourding to chiltons manual) and bought a new ignition module (which was what i thought it was when it tested bad at auto store). still no spark.
it is probly helpful if i say it is a accell dizzy not stock. nothing special just a cheapo accell
any help please
Old Dec 20, 2010 | 05:30 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: wont start
disregard. Didn't read the "no spark is the problem part"
Old Dec 20, 2010 | 08:21 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Cranky, Me Too !
Grab a test light (the type for testing for voltage, not a continuity tester).
Connect one lead to the coil primary
(the ignition module side not the key side) and the other lead to ground.
Crank the engine.
Does the test light flash while cranking?
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Dec 24, 2010 | 02:23 PM
Axle/Gears: 3.08
Re: wont start
update i have replaced the ignition module and the coil with tested good new ones and still no spark battery is fully charged and dizzy is getting power from batt
any other ideas
Old Dec 27, 2010 | 09:59 AM
NINÅ's Avatar
Transmission: 765R4
What was the result of the test in post #3?
Happy Racing!
Old Dec 29, 2010 | 08:16 PM
Axle/Gears: 3.08
Re: wont start
ok so i was trying to do the test and i unpluged the tack cable while having someone crank it and it started right up.
as long as i leave the tack cable unpluged no problms
Old Dec 30, 2010 | 03:39 PM
NINÅ's Avatar
Transmission: 765R4
Tachy Solution
That means there is a short in the tach or the wiring going to it.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Jan 10, 2011 | 08:12 PM
Axle/Gears: 3.08
Re: Tachy Solution
yup found the tach cable shorting to firewal and repaired it works great now thank you very much for all your help NINA
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
