Heater Problems
Old Feb 1, 2011 | 02:44 PM
chrishall1984's Avatar
Car: 1991 Chevy Camaro Z28
Engine: L98 350 5.7L
Transmission: TH700R4
Heater Problems
I have a 1991 Z28 that the heat does not work in it. I just replaced the fan motor. But I am thinking it could be the blower resistor or the selector switch that is keeping it from working. Any inputs on the situation. Thanks for the help.
Old Feb 1, 2011 | 03:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Heater Problems
The resistor I think is only used for lower fan speeds, so fan should still blow on high maybe. Did you check the relay - it's under the hood on or close to the heater box.
Old Feb 1, 2011 | 03:21 PM
Re: Heater Problems
Yea it has recently been replaced as well because i started with the cheap things first.
Old Feb 1, 2011 | 03:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
This Thread Is Hot Air
OK that means it doesn’t work in any speed.
We will assume the car has or had AC
(if it never did the circuit is different).
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the blower relay pin A red wire.
It doesn’t matter what position the ignition key is in.
Is there power on the
red wire?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Feb 1, 2011 | 04:17 PM
Re: Heater Problems
there was 12 v going to it
Old Feb 1, 2011 | 04:18 PM
Re: Heater Problems
it had ac by the way just takin out of car
Old Feb 1, 2011 | 04:20 PM
Re: Heater Problems
the air coming out of vents does get hot but does not have any force behind it coming out of vents. not even through all selections on blower speed or through heater and defrost and vent selections. fan motor does not kick on at all
Old Feb 1, 2011 | 04:47 PM
NINÅ's Avatar
Transmission: 765R4
OK put 12 volts directly to the + terminal of the blower motor.
Don’t apply a
wire.
We want to find out if the new blower motor is grounded properly.
So, when you applied the 12 volts did the blower run?
If yes, jump pin A
red wire to pin E purple wire.
Did the blower run?
Happy Racing!
Old Feb 1, 2011 | 04:53 PM
Re: Heater Problems
Ok i will go out and try that later today to see if it works
Old Feb 1, 2011 | 05:04 PM
Re: Heater Problems
Ok I jumped the red and purple wires and blower motor came on. Could I wire in a toggle switch to where the relay goes in and just use it or is there something better I can do.
Old Feb 1, 2011 | 05:17 PM
Re: Heater Problems
Ok I checked the vents and there is still nothing coming out of them for some reason even with the blower motor running
Old Feb 1, 2011 | 06:22 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
You may have some vermin making a nest inside, leaves collected in there.
When you had the blower out was there any carp inside? did you look or feel for anything?
Old Feb 1, 2011 | 06:36 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Heater Problems
let me ask you a question...
when you turn it from cool to heat does the air go away?
Old Feb 1, 2011 | 07:09 PM
Re: Heater Problems
There were no leaves or anything in there. Well there is no air at all coming out really at all anyways then while ur accelerate and drive down the road heat comes out then or cool air whatever u have it on.
Old Feb 1, 2011 | 07:13 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
Are you getting air from your defrost vents?
You may just be having an issue with vacuum and the vacuum operated blend doors.
58mark's Avatar
Re: Heater Problems
sounds like a couple of different problems..
first of all, the problem with the fan motor not kicking on could be your switch in the dash
secondly, when you are feeling for air coming out different places, check the defroster vents first. If you have a lack of vacuum, all the air will com out the defrosters
Old Feb 1, 2011 | 07:16 PM
Re: Heater Problems
That is where it is only coming out unless the car has been driving for awhile then it tries to come out the other vents
Old Feb 1, 2011 | 07:17 PM
58mark's Avatar
Re: Heater Problems
ok, you have a vacumm problem.. the easiest place to check is the servo under the dash, passenger side, by the kick panel
You need to check every vacuum line, everywhere...
Old Feb 1, 2011 | 07:21 PM
Re: Heater Problems
Ok whats the easiest way to check for that and is it just a black line or is it a diffrent color. And as for the fan could it be the blower speed selector?
Old Feb 1, 2011 | 07:23 PM
Re: Heater Problems
And does that have anything to do with engine vacuum because ive had to check for leaks there and there are not any. What does the servo look like do you have any pics.
58mark's Avatar
Re: Heater Problems
yeah, it very well could be
as for the vacuum line, I think it's orange... terminates into a vacuum module. get on your back in the floorboard, slide under the dash and look up... you'll see it
Old Feb 1, 2011 | 07:28 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
I would just start under the hood.
There is a check valve coming off you TPI's upper plenum above the fuel pressure regulator. It is also where your vacuum starts from.
The line coming out of the check valve is a plastic tube going into the harness for the controls. That plastic line can easily break or split.
There is also a hose on the back side of that valve. It goes to a resivour ball located under the Evap canister on the left side of the car. You need to look from the underside to see it. Make sure its not cracked.
Also that last hose may T off to the cruise control if equiped.
Old Feb 1, 2011 | 07:32 PM
Re: Heater Problems
how far in the harness does it go so i know how far to look down the harness
Old Feb 1, 2011 | 07:41 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
There is too many people here going back and forth. I'll let the other poster who was helping handle it.
BTW, I do believe that the orange vacuum hose is to close off the outside door for MAX AC so you have no outside air coming in.
Old Feb 1, 2011 | 07:42 PM
58mark's Avatar
Re: Heater Problems
that's possible.. All I said was it was the easiest one to get to
Old Feb 1, 2011 | 07:43 PM
Re: Heater Problems
Alright thank you
Old Feb 1, 2011 | 07:46 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
Who knows, maybe if the OP follows that line and finds the fesh air door he might see a bunch of animals and nuts and berries fall out of it!
I'll still help but between two of us we are sending you in different directions.
Old Feb 1, 2011 | 07:48 PM
58mark's Avatar
Re: Heater Problems
i'm wondering if somehow his evaporator is clogged up....
Old Feb 1, 2011 | 07:56 PM
Re: Heater Problems
Do you think that may be the problem because the air still gets warm and everthing it just doesnt blow.
Old Feb 1, 2011 | 07:57 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
Thats what I was thinking, why I asked about anything behind the fan when he had it out. It would make the air flowing slower. But the blend doors switching while on and off the throttle could be due to vacuum. And defrost being default if there is no vacuum.
Old Feb 1, 2011 | 07:58 PM
Re: Heater Problems
So there could be no vacuum but would that have anything to do with heater core
Old Feb 1, 2011 | 08:00 PM
58mark's Avatar
Re: Heater Problems
I bet it's mostly a vacuum problem... If he can hot wire the blower motor, start the car, and feel the air coming out the defroster vents, then He should first fix the vacuum problem before he starts fretting about a plugged up evap
I thought his problem might be similar to what I have with my car, but it's not...
you mind taking a look at this?
https://www.thirdgen.org/forums/inte...ater-core.html
Old Feb 1, 2011 | 08:01 PM
Re: Heater Problems
so look for vacuum leak first then if not check heater core
Old Feb 1, 2011 | 08:02 PM
58mark's Avatar
Re: Heater Problems
this is my bet...
your core is fine.. but without the airflow, you're never going to feel the effects of it. Your airflow is messed up
Old Feb 1, 2011 | 08:03 PM
Re: Heater Problems
ok
Old Feb 1, 2011 | 08:14 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Heater Problems
This poster seemed to be having similar issues with the vents changing.
https://www.thirdgen.org/forums/cool...-problems.html
But was unable to resolve that issue. Maybe you will have different results
Old Feb 2, 2011 | 09:03 AM
NINÅ's Avatar
Transmission: 765R4
Could I wire in a toggle switch to where the relay goes…….
You could, however there’s no reason you can’t fix this the right way.
I hear ya about no air from the vents even with the blower running.
As the other posters said it’s a vacuum problem.
So now, the electrical problem.
Gain access to the back of the HVAC panel, put the HVAC selector in the NORM position, and probe the
brown wire going to the blower speed selector.
Is there power there?
If no, probe the
brown wire going to the mode selector.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Feb 2, 2011 | 01:11 PM
Re: Heater Problems
there was not power at either one of them
Old Feb 2, 2011 | 02:01 PM
NINÅ's Avatar
Transmission: 765R4
Re: post #37, the measurements must be taken with the ignition key in the RUN position, if you did it that way, with the ignition key still in the RUN position probe both sides of the HTR A/C fuse.
Is there power on both sides?
If yes, there is a bad connection from the wire that exit’s the fuse block and goes to the Mode Selector.
If no, you have a bad Fusible Link near the starter solenoid, or the wiring to it.
Fusible Links usually look like a one inch plastic rod in line with the wire.
Happy Racing!
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
