Hi Beam Problem
Old Feb 1, 2011 | 02:46 PM
chrishall1984's Avatar
Car: 1991 Chevy Camaro Z28
Engine: L98 350 5.7L
Transmission: TH700R4
Hi Beam Problem
I can not turn my high beams on. The switch work because if I push it myself it turns on. The problem I am having is the rod in the steering colume is not attached to the signal lever and I can't figure out if there is a piece missing or where it connects too. Thanks for the help.
Old Feb 1, 2011 | 05:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Hi Beam Problem
Are you sure the rod is not moving at all, or is it just not moving enough to actuate the switch? Switch may need to be adjusted to make it work.
Old Feb 1, 2011 | 06:07 PM
Re: Hi Beam Problem
Its not connected at all i already checked inside the colume
Old Feb 1, 2011 | 06:13 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Hi Beam Problem
Agreed, push up on the rod at the switch and hold it while working the lever as if you're switching between high and low. If the rod moves, loosen the two bolts holding the switch and adjust it up.
If the rod does not move then you're going to need to take apart the column, remove the steering wheel, lock plate, signal switch, etc..
Before you tear apart the column though it may be wise to go out to the yard, if you have any self pullers, and take apart a column there. You should be able to see how its done and what parts you may need.
There is a small plastic guide thing that is pushed by a tab on the wiper switch. Other than that its not much else.
Old Feb 1, 2011 | 06:16 PM
Re: Hi Beam Problem
ok thank you
Old Feb 5, 2011 | 01:00 PM
tr6guy's Avatar
Car: '72 Triumph TR6, '85 Camaro
Engine: 2.8 V6
Re: Hi Beam Problem
I'll throw my two cents in... There's a good tech article on this site on how to install an "old fashion" foot switch to activate the high beams. I ended up doing that rather than taking apart the steering column. It's very easy to do. It was fun, too, to watch the guys a the state inspection stations trying to figure out how to operate the foot switch - until they stopped checking that sort of thing. Cheers.
Old Feb 5, 2011 | 01:42 PM
Re: Hi Beam Problem
where is that article at on here what is it labled
Old Feb 5, 2011 | 01:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Hi Beam Problem
https://www.thirdgen.org/technical-articles
Old Feb 5, 2011 | 01:52 PM
Re: Hi Beam Problem
thank you that helps alot actually
Old Feb 5, 2011 | 06:20 PM
Re: Hi Beam Problem
quick question the dimmier switch for the floor mount only has three connectors but the one in the car has 4 wires coming off of it how does it hook up
Old Feb 5, 2011 | 07:36 PM
Re: Hi Beam Problem
alright figured it out the connector plugs right into the floor dimmer switch
Old Apr 7, 2011 | 12:20 PM
Murraydpsr90's Avatar
Car: 1990 camaro rs
Engine: 5.0
Re: Hi Beam Problem
Where r the two screws
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
