High beam issue
Old Feb 21, 2011 | 09:13 PM
Murraydpsr90's Avatar
Car: 1990 camaro rs
Engine: 5.0
High beam issue
When I pull the lever for the high beams there is no click any ideas
Old Feb 21, 2011 | 09:41 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: High beam issue
this question is very common . the switch itself , wich is attached to the column slips out of position . 20+ yrs. of flipping beams does that . a rod goes from the lever to the switch mounted on the column . remove under dash cover , move lever , find rod , find sw. , loosen mounting screws on sw. , move sw. up to remove slop from rod , tighten screws , good to go . good luck , try search function , lots more details .
Old Feb 22, 2011 | 12:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: High beam issue
Make sure your tilt wheel (if you have) is at the normal position for driving before you adjust the switch. The switch is located just above brake pedal.
Old Mar 20, 2011 | 01:45 AM
86speediroc's Avatar
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
Re: High beam issue
hey in mine the plastic piece in the column fell out a few yrs ago when a budy had the wheel off how to i get it back in i put in place but it just pushes the rod out to the left instead of down activating the switch. any sugestions/pics????
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
