vats problem
Old Apr 21, 2011 | 09:52 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
vats problem
hello, i have a 91 z28 camaro tpi tired of the vats and i was wondering if i can change the harness completely to one that didnt have vats one from an 88 iroc tpi will the connecter on the firewall fit exactly the same really dont want to go back to vats . any help is greatly appreciated
Old Apr 21, 2011 | 10:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vats problem
Originally Posted by irocdls1
if i can change the harness to one that didnt have vats one from an 88 iroc tpi will the connecter on the firewall fit exactly the same
Need to swap computer to 88 one as well
Easier to install VATS bypass module that does away with VATS altogether by supplying the correct signal to computer
http://www.bakerelectronix.com/products_vats/
Old Apr 21, 2011 | 10:30 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: vats problem
where is the vats module located?I know its under the dash.close to the drivers side or computer side?
Old Apr 22, 2011 | 10:20 AM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
Re: vats problem
yeah i know but i tried doing that pellet thing with resistance and changining the vats module but havent got i runnining yet fairly new to the whole vats thing. Always liked the idea of mass air anyways. So do u think the harness connecter will fit in the firewall next the brake booster . I know for sure i need the computer and an esc . thanks for any help
Old Apr 22, 2011 | 11:13 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: vats problem
I may be entirely wrong here but I think the harness that needs to be changed is the fuel injection harness and the computer for it. the main parts of the rest are the same except maybe for the starter relay behind the driver kick panel. Just make sure that it is the right type of injection MAF or MAP Speed Density and swap to the earlier matching FI wiring and computer. This wiring goes through the body behind the passenger kick panel area. If the computer is not changed out then it will still be seeking the vats signal as that is part of the programming. Or an alternative is to send the computer (ECM) to somebody and have them do a vats delete then bypass the starter relay. Or still by a VATS bypass module that would be wired up to the Vats enable wire on the ECM.
Old Apr 22, 2011 | 04:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: vats problem
There would be no need in swapping harnesses I wouldn't think - just swapping chips. But that assumes keeping the same system, and I'm guessing you are saying you'd rather have a MAF system instead of a SD system? Most folks switch the other way I thought, b/c there's more can be done with a SD system.
But that is a WHOLE LOTTA TROUBLE to simply get rid of VATS, when a VATS bypass is easily gotten, cheap, and a very easy install.
Old Apr 23, 2011 | 01:10 AM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
Re: vats problem
well its because i can get a fuel injection harness and computer for cheap from an 88 iroc which has no vats and ive already tried all of the things you all have suggestedand no luck so does anyone think that the connecter next to the fire wall is the same for 88 -91 will it just plug in directly
Old Apr 23, 2011 | 01:16 AM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: vats problem
in the 89 RS im parting out the modual was between the steering wheel and center council mounted to the A/C ducting
Old Apr 23, 2011 | 06:41 AM
Car: 1992 RS
Engine: Carbed 350
Re: vats problem
So you've tried the bypass with resistors, as well as a seperate VATS bypass module, and neither worked? You must not have it wired correctly, or else got the wrong bypass module (there are 2 different frequencies 30Hz and 50Hz - most these days do either freq).
What's the issue - is it a starting issue or a running issue? Maybe it's not VATS related at all. What happens if you turn on the key, and jump the starter directly from battery? (ie use a 10ga wire, touch pos battery terminal and at same time touch starter terminal that has the purple wire on it)
Old Apr 23, 2011 | 10:36 AM
irocdls1's Avatar
Engine: ls1
Transmission: 4l60e
Re: vats problem
its because the is no fire to the injectors at all
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
