instrument cluster lights went out
Old Jun 19, 2011 | 03:24 PM
sabresfan's Avatar
Car: Looking for a new thirdgen
Engine: hopefully a 5.7L 350
Last week my cluster lights when out completely when I pulled my headlight switch. Any ideas? is there a fuse I should check? First time i have experienced problems with this
And my tach needle is very wobly, not sure if that is normal
Old Jun 20, 2011 | 09:33 PM
sabresfan's Avatar
Re: instrument cluster lights went out
no one has any idea?
Old Jun 20, 2011 | 09:44 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
Subscribing...
I have a similar problem, I havent had dash lights in over a year, all the time Ive had, parts replaced, and threads started I have yet to figure it out...
Old Jun 21, 2011 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is there any possibility that you turned the dash lights off (perhaps inadvertently twisting the **** a bit)? Sorry, had to ask.
JamesC
Old Jun 21, 2011 | 09:32 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Does the shifter console light and heater panel light work? They run off the same fuse as the instrument panel lights. If not it's likely the fuse - labelled INST LPS or the like. If so, likely a loose/dirty pin on the cluster loom plug.
OR - when you say you pulled your headlight switch - do you mean as in removed from the dash completely? You may have accidentally dislodged the connector to the dimmer **** when you pulled off the connector to the headlight switch.
Old Jun 21, 2011 | 11:22 PM
sabresfan's Avatar
i think it has to be the fuse at this point. i might make sure the **** is in correctly as well. the headlights still function properly and all that. its tough to check it during the day time because the lights are so dim but im planning on pulling it apart to put some brighter led's in along with my 145 mph speedometer i got for 20 bucks
Old Jun 22, 2011 | 08:31 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
if not the fuse it could be the headlight switch: the black box behind the **** inside the dash. The switch has something like a 10 pin connector on of the pins being for the dash lights... the switch is $10 (with the bro hookup) to $20.
Old Jun 22, 2011 | 11:40 PM
sabresfan's Avatar
thanks JamesC. I twisted the **** back and forth and eventually found the setting the powers the instrument cluster lights. easiest fix ive made on my car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jeremys87
Jul 14, 2022 09:08 PM
fasteddi
Sep 10, 2015 09:32 AM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
