1990 RS fuse box
Old Jun 23, 2011 | 06:41 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
1990 RS fuse box
i baught a 1990 camaro RS yesterday, it took us about 4 hours to load and unload it, i put a hot battery in it last night and tried to crank it up but the key wouldn't even spin over, i located the fuse box early this morning only to find that it doesn't have an ignition fuse, and a regular fuse won't go in the slot, so can anybody attatch a pic of a full fuse box it would be greatly appreciated... thanks TGO
Old Jun 23, 2011 | 07:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1990 RS fuse box
There is no ignition fuse.
There are several slots for accessories - given to us by the factory for adding goodies. They all have just a single slot (where a fuse needs two slots). They are:
IGN - ignition - gets 12v+ only when key is on
RADIO - gets 12v+ when radio is on (ie when key is on, or when key in ACC position)
BAT - gets 12v+ all the time, regardless of the key.
LPS - gets 12v+ when the lights are on
These come in handy - use standard 1/4in male spade terminals and insert to tap them.
Now - to the starting ...
1) does the fuel pump prime when key is turned on?
2) Does the starter even click at all?
3) is the security light on the dash on when you try to crank car?
4) does the key have a chip (pellet) in it?
Look at thirdgen.org/vats to rwad up on VATS if the security light is on, or if key has no pellet in it.
You can test starter by applying 12v directly to the starter terminal that has the purple wire to it - use a 10ga jump wire off batt pos terminal. If starter turns, then you know starter is good, and probably need to look at the VATS issue.
Old Jun 23, 2011 | 07:28 PM
Car: 1992 RS
Engine: Carbed 350
Also look at these: http://www.austinthirdgen.org/index.php?pid=10
http://www.austinthirdgen.org/index.php?pid=38
And here you can see the fuse block - the single slots I described are the ones with a line through them (they do not take fuses):
http://www.austinthirdgen.org/mkport..._continued.gif
Old Jun 23, 2011 | 09:25 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
what does the security light look like? there is one light when u turn the key on it flash's infl reset...
Old Jun 23, 2011 | 09:31 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
infl rest*
Old Jun 24, 2011 | 01:47 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
after an hour of trying to spin the motor by hand with a huge breaker bar, we've come to the conclusion that the motor is locked up...
Old Jun 25, 2011 | 06:42 PM
Car: 1992 RS
Engine: Carbed 350
Did you remove a spark plug (or all of them)? Sometimes it's impossible to turn a motor by hand without removing plugs (compression pressure).
INFL REST refers to the air bag (Inflatable Restraint) - it should come on (maybe flash) BUT go off after startup (as with all the other dash lights). The "security light reads "SECURITY".
Old Jun 26, 2011 | 09:24 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
na haven't tried that, but the motor has been sittin out in weather for like 3 years so i'm pretty sure the rings have rusted to the cylinder wall
Old Dec 18, 2012 | 07:57 PM
Mprchrsgirl's Avatar
Does anyone know what the fuse for the headlights is called on a 1990 Camaro rs? Does it even have a fuse? HELP!!! I am stumped!
Old Dec 19, 2012 | 08:20 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
No headlight fuses on our Chevys. But there is a circuit breaker on the headlight switch (kinda inconvenient, I know, but hey, you bought a Chevy, deal with it :-D ).
Btw, next time feel free to start a new thread instead of resurrecting a dead one from the past.
Tweeks25
Sep 17, 2015 08:04 AM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
ynk1121
Sep 12, 2015 12:27 AM
64goatman
Sep 9, 2015 01:09 PM
