Stock dual fan
Old Jul 6, 2011 | 07:51 AM
lonesomeloser's Avatar
Car: 1983 Z28
Stock dual fan
On the back of the fans, which is the + and - ? I bought a wiring kit from Summit and am installing it right now. I didn't know if it would run or not if I had the terminals reversed. I also didn't know if the fans would reverse flow if the terminals were backwards.
Old Jul 6, 2011 | 08:18 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Stock dual fan
There DC if you reverse them they will push air into the radiator instead of pull.
Old Jul 6, 2011 | 06:51 PM
Car: 1983 Z28
Re: Stock dual fan
So which is the correct way to connect them?
Old Jul 6, 2011 | 06:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Stock dual fan
Do you still have the old plugs? They only go in one way. See which way they go in and what side the black(ground) wire is on. Other one must be positive.
Old Jul 6, 2011 | 07:19 PM
Engine: 383 SBC
Re: Stock dual fan
You want them to blow air towards the motor. Whichever way that is. I upgraded and sold the stock fans a long time ago.
onefreakz
May 14, 2018 12:15 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
Leggman1
Aug 6, 2015 04:15 AM
