Distributor Wiring Help
Old Sep 11, 2011 | 10:17 AM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
Hey guys. I'm putting a HEI vacuum advance dizzy on my new engine and would like to splice the new connections into the existing harness, but I'm not sure which wires are which. The car the engine is going into is an 87, and had an external coil. If anyone has a wiring diagram, that would be cool too.
Old Sep 11, 2011 | 12:30 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Distributor Wiring Help
is your new engine computer controlled at all? if yes, you cant use the HEI.
Old Sep 11, 2011 | 04:51 PM
jminton's Avatar
Car: 1985 IROC
No, it won't be computer controlled.
Old Sep 11, 2011 | 04:54 PM
travis401's Avatar
Car: 91 Camaro RS
then all you need is a switch 12v source to run to the bat terminal on the dizzy.
Old Sep 11, 2011 | 04:58 PM
travis401's Avatar
Car: 91 Camaro RS
get a test light or a multimeter and test wires untill you find one thats only getting 12v with the key in the on position. then slap a female spade connector on it and plug it in and youre good to go.
Old Sep 11, 2011 | 05:34 PM
jminton's Avatar
Car: 1985 IROC
That sounds like a plan. Would you happen to know how to test, or would know which wire is tach?
Old Sep 11, 2011 | 05:36 PM
travis401's Avatar
Car: 91 Camaro RS
tach should be the white wire on the coil plug. thick pink was switched 12v i think...not 100% sure though.
Old Sep 11, 2011 | 05:47 PM
jminton's Avatar
Car: 1985 IROC
you the man.
Old Sep 11, 2011 | 06:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The 2 wires that went to the remote coil get moved to the HEI cap
Done
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
