park neutral switch orange/black b10 ?
Old Nov 7, 2011 | 06:13 AM
kreator33's Avatar
hey,on a 87 tpi ,when you install a manual trans,what to do with the orange/black wire going from ecm b10 to park neutral safety switch? just leave it open,or ground it?
Old Nov 7, 2011 | 02:01 PM
Brads RS's Avatar
Re: park neutral switch orange/black b10 ?
Im not 100% on this but i think if you ground it, none of your emissions stuff will work cus it will think you are in park all the time. Not really sure how to go about that. Hopefully someone else will chime in.
Old Nov 7, 2011 | 03:01 PM
kreator33's Avatar
that would be allright, all my emmission stuff is in the garbage anyway,there is no such law where i am,it would even help to not set a code for them,but will it bother something else?that i actually need?if not i'll ground it
Old Nov 7, 2011 | 03:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you need to wire in the manuals nuetral safety switch into the circuit to prevent starting the car in gear. atleast thats what i would believe.
Old Nov 7, 2011 | 03:47 PM
kreator33's Avatar
yeah thats done already,just wondering if i should trick the ecm by grounding the b10,i wonder if the ecm is gonna act as if its in open loop or something,
Old Nov 7, 2011 | 04:02 PM
travis401's Avatar
Car: 91 Camaro RS
that i dont know. give a shot and see what happens?
Old Nov 7, 2011 | 09:03 PM
Brads RS's Avatar
Grounding the wire should not put you in open loop, just wont enable emission junk.
Old Nov 7, 2011 | 11:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Leave it open.
On the auto car it just tells the ECM if car is in gear so it can adjust idle revs.
Has no effect on anything else
Old Mar 13, 2012 | 03:16 PM
kreator33's Avatar
ok,well is it ok if i do ground it? i dont have any emmission stuff anyway,
Old Mar 13, 2012 | 04:22 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Can you read?
Leave it open
It has nothing to do with emissions
Old Mar 13, 2012 | 04:44 PM
kreator33's Avatar
was that ''can you read?'' really necessary? no need to be a dick,what i meant was that i had it grounded because of what that book was saying, ,i understand that you say it can be left open,my question was to know wether or not it would matter if it WAS grounded,pretty easy to be rude for no reason when youre not in person,would probly be different if you were in my face.maybe you could ask why im asking that instead of being a smart ***,thanks for the info anyway,now can you answer my question,,,,read carefully,CAN I GROUND IT TOO! or do i have to go in the harness under the dash and cut it open.if i have to, ill do it,but if it makes no difference, ill leave it grounded.thats all,
with all the stupid stuff i see on here i could be an ******* too if i wanted too, and believe me you found your match if i wanted to blast someone,but i'm civilized enough to know that there is nothing to win in tryin to make people feel stupid.it obviously didnt work with me.didnt make you smarter either. now lets put the hard feelings aside and talk cars,sorry for telling you all this,but i dont like being talked to as if i was 5 not that its ok to be a dick to a 5 year old either
Old Mar 13, 2012 | 05:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
,my question was to know wether or not it would matter if it WAS grounded.
Not what you asked ; you referred to you having no emissions
Switch is only there for AUTO cars so it can change idle revs when in gear.
Not needed or used for stick cars
Who knows , I didn't do the factory computer programming.
Maybe the stick tune doesn't look for that input / maybe it does.
You are now in a position to find out if it matters
Old Mar 14, 2012 | 02:19 PM
kreator33's Avatar
ok thanks, i didnt do any programming either,the reason why i talked about emission, is that i read a tpi book that mensions that by grounding that b10 wire,its cheats the computer into not setting a code if you delete egr,a/c and a few other deletes. so i went and did it,and now i was wondering if it was a mistake since you told me to leave it open,i wanted to know if it really had to and for what reason. im gonna have a prom reprogramed anyway now, so i can set these options off without having to play with that b10.its comfusing when you see 2 different things and have to decide wich is right
Old Mar 14, 2012 | 02:20 PM
kreator33's Avatar
i guess im gonna unplugg it and leave it open,thanks
83 Crossfire TA
Jan 3, 2016 01:26 PM
luvofjah
Sep 3, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Slush92RS
Sep 2, 2015 08:56 PM
5spdcamaro
Aug 28, 2015 02:12 AM
